t-45 swap trouble codes - TCCoA Forums
post #1 of 13 (permalink) Old 06-13-2006, 08:30 PM Thread Starter
Resident drifter
slidebird91's Avatar
when I swapped in my t-45, naturally I set off like 7 or so codes. I got an exemption for emissions inspection this year, but they said I need to have the codes gone by next year. Has any one tried using a Mustang GT computer or anything of that sort to alleviate this problem?
slidebird91 is offline
post #2 of 13 (permalink) Old 06-13-2006, 09:30 PM
Just call lonnie at blueovalchips.com and have him burn you a chip to delete the auto trans controls.
By the way, how does the car run without a tune? I have heard that it becomes almost undrivable because the computer randomly retards timing and stuff based on when it thinks it should be shifting. Is this true?
Mike
MadMikeyL is online now
post #3 of 13 (permalink) Old 06-14-2006, 12:54 PM Thread Starter
Resident drifter
Your question would explain why I get what seem to be random misfires. This only happens occasionally, and when it isnt doing that it runs beautifully. The car is obdII, though, so can you burn a chip or do you have to have some other type of tune?
post #4 of 13 (permalink) Old 06-14-2006, 12:58 PM
02 Explorer Pioneer
timb's Avatar
You can have a chip burned which will piggyback on the EEC or you can have the EEC reflashed. Either way make sure you call Lonnie
Birdless
timb is offline
post #5 of 13 (permalink) Old 02-06-2009, 04:54 AM
Wow this solves My Problem!!
Scottie6.0 is offline
post #6 of 13 (permalink) Old 02-07-2009, 01:01 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Haven't I read somewhere that the mustang computer will go straight into a 97 t-bird(possibly 96 also)? If that's the case it would be quick and easy to swap in an ECM. Of course advanced timing and all that stuff with the chip is cool too.
-Rob
Rob is offline
post #7 of 13 (permalink) Old 02-09-2009, 01:45 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
I'm not sure if that will work or not, but you'd probably need a tune anyways if you did that so you could turn off the PATS function in the stang EEC.
-Rob
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #8 of 13 (permalink) Old 02-11-2009, 10:18 PM
did you swap in a T45?
slamn_mn12 is offline
post #9 of 13 (permalink) Old 02-12-2009, 12:54 AM
Nah, not yet, but Im about to and I was Wunderin how I would program it once I got it..
What does A full t-45 Swap cost??
post #10 of 13 (permalink) Old 02-12-2009, 01:01 AM
Baby Huey
warmaster259's Avatar
I think mine may have been cheaper than most.
T-45 $80
Clutch $160
Flywheel $120
Hydraulics $45
Driveshaft (shortened) $90
Clutch Pedal $10
Clutch Arm and ball $50
Tune $75
Jim
warmaster259 is offline
post #11 of 13 (permalink) Old 02-12-2009, 01:21 AM
^where did you order all of it from!??
post #12 of 13 (permalink) Old 02-12-2009, 01:31 AM
Baby Huey
Trans was from a local guy who was getting out of the hobby, the rest was pieced together by myself by searching ebay and local resources.
Jim
post #13 of 13 (permalink) Old 02-12-2009, 01:39 AM
Damb.. Im trying to find a sorce where I can get every thing I need..
Any Ideas??
