J-Mod-- Valve Body not coming out - TCCoA Forums
post #1 of 6 (permalink) Old 06-17-2006, 11:21 PM Thread Starter
Okay, I started the J-Mod today but stopped when the valve body did not release from the transmission. I have removed all the electrical connections, the EPC/VFS bolt and bracket, all 12 outter 8mm bolts, and have loosened the 11 remaining 8mm bolts, but the valve body is not dropping free from the transmission. Did I miss something somewhere??
From reading through the posts here and the directions, numerous times, I was under the impression that the VB should separate fairly easily once all bolts were removed. I do not want to pry on anything in there, since the goal is to fix and not break.
Afterthought:
After going through the numbers... I think we may have missed a bolt although I am nto sure where. We have removed or loosened all the 8mm bolts that we saw... could there be one hiding?
shadowhunter is offline
post #2 of 6 (permalink) Old 06-18-2006, 12:39 AM
Did you get the one that hold the rooster-comb for the detents?? I missed that one when I did mine.
Jay
FordMan77 is offline
post #3 of 6 (permalink) Old 06-18-2006, 01:13 AM Thread Starter
yep got that one, I believe that counts as 1 and there are 24 others. I think the one I missed after looking at the torque sequence picture is the one that holds or is next to the shift control solenoids. I do not have the car here to verify but that is my guess at this point.
If that is not the case, I will do the 1-2 accumulator since it is right there (i believe) and put the new pan and filter back on and run it as is. Don't want to cause more damage than I need to.
Thanks!!
post #4 of 6 (permalink) Old 06-18-2006, 02:47 AM
Chapter Director Coordinator
jamesD's Avatar
remove all the 8mm bolts and it will come off.. they are different because they are hex flange head bolts.. should have 1 or two near the TPS as well
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #5 of 6 (permalink) Old 06-18-2006, 07:55 AM
Darrin's Avatar
You missed the one hiding between the solenoids and the plate I bet.
Darrin
Darrin is offline
post #6 of 6 (permalink) Old 06-19-2006, 12:33 AM Thread Starter
That's exactly the one we missed right there by the shift solenoids. However due to the condition of the current fluid, brown , we decided to flush with general mercon for a bit before adding the good stuff. So for now the J-Mod has been postponed, but this will give me time to get a cooler and trans temp gauge that I want.
Thanks for the replies.
