Diff rebuild or new carrier? - TCCoA Forums
post #1 of 25 (permalink) Old 06-18-2006, 02:14 PM Thread Starter
MadGoat's Avatar
Send a message via AIM to MadGoat Send a message via MSN to MadGoat
Does anyone know what an average cost would be to have a diff rebuilt? same gears and everything, just new internals?
or would it be cheaper to buy a trac-lok carrier and have that installed?
Im looking to get my diff rebuilt and a new aluminum one piece drive shaft put in. Since I have a BAD vibration and the car could use the upgrade anyway.
mg
MadGoat's Birds
94 Thunderbird LX 4.6L PI
03 Aluminum PI Engine, J-Mod, Aluminum one piece drive shaft, 3.27's, 2.5" to single 3" custom MagnaFlow exhaust, 07 17x8 Bullit Wheels
97 Thunderbird LX 4.6L V8
RIP
MadGoat is offline
post #2 of 25 (permalink) Old 06-18-2006, 02:34 PM
I generally charge $250 to set up one of these plus the labor to install it. If you do not have a traction lok carrier you need it anyway,but still you will have to have the rear built. The carrier is not the entire diff.
post #3 of 25 (permalink) Old 06-18-2006, 03:00 PM Thread Starter
MadGoat's Avatar
I'd be taking it out and installing it myself, It is a T-lok unit itself... just needs to be rebuilt. 250 you say? wow... I was thinking along the 150-175 line.
thank you though, now I know what to expect.
MG
MadGoat's Birds
RIP
MadGoat is offline
post #4 of 25 (permalink) Old 06-18-2006, 10:16 PM
$250 is actually a pretty good price. Most shops around here charge quite a bit more than that.
-Rod
post #5 of 25 (permalink) Old 06-19-2006, 06:37 AM
yeah shops can be nuts on this stuff I have heard quotes up to $600 to rebuild them, thats not including install or parts.
post #6 of 25 (permalink) Old 06-19-2006, 12:21 PM
i paid 350 i think for mine rebuild with 3.73s and trac lock.. installed
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #7 of 25 (permalink) Old 06-19-2006, 02:24 PM
girdnerg's Avatar
Just for future reference. What does the customer get for $250? It sounds as if at least some parts are included. I may be needing your services soon.
Rob
girdnerg is offline
post #8 of 25 (permalink) Old 06-19-2006, 07:11 PM
$250 covers assembly lubes and silicone to seal the case all bearings,seals,clutches or hard parts are not included. I will however machine mustang sidegears if needed. Basically the $250 covers all of the time spent cleaning the housing and soap required there (gear oil will make a nice parts washer stink quickly). The time spent setting up the pinion depth backlash and side spacing is what is to be considered not to mention rebuilding the traction lock clutches which I can and often stack to 4 plates per side instead of 3.
post #9 of 25 (permalink) Old 06-19-2006, 07:38 PM Thread Starter
MadGoat's Avatar
ok so how do i know if mine is in need of being rebuilt? I talked to all the guys I could track down at work and there had no idea.
anyone?
MG
MadGoat's Birds
RIP
MadGoat is offline
post #10 of 25 (permalink) Old 06-19-2006, 07:53 PM
is it noisy?
post #11 of 25 (permalink) Old 06-19-2006, 07:59 PM Thread Starter
MadGoat's Avatar
no, well....
See I have this BAD vibration... over 50 it shakes the whole car like its gonna fall apart. And in doing so I really cant hear it.
Although when I jacked up the rear end and pulled the tires off... had my wife bring the car up to speed while I was under it (scary stuff) .... The diff didnt seem to be the sorce of the vibration nor was I able to hear any "unusual" noise from the diff itself.
I could lay my finger on the drive shaft while it was runnin at 50-55mph and it would vibrate my finger pretty good (about 1/4+ an inch in movment).
whaddya think?
MadGoat's Birds
RIP
MadGoat is offline
post #12 of 25 (permalink) Old 06-19-2006, 08:03 PM
That could be a bad pinion bearing,rear trans bushing or driveshaft.
post #13 of 25 (permalink) Old 06-19-2006, 08:25 PM Thread Starter
MadGoat's Avatar
how would I diag that? Im going to get a mark aluminum shaft in a couple days anyway... thats one diag out of the way.
I assume the rear trans bushing is the big hydro mount ?
what is a pinion bearing?
MG
MadGoat's Birds
RIP
MadGoat is offline
post #14 of 25 (permalink) Old 06-19-2006, 08:28 PM
The pinion bearing is inside the differential behind the flange.
post #15 of 25 (permalink) Old 06-19-2006, 08:32 PM Thread Starter
MadGoat's Avatar
is there a way to diag that to see if its the culprit?
(without tearing into it?)
MG
MadGoat's Birds
RIP
MadGoat is offline
post #16 of 25 (permalink) Old 06-19-2006, 08:41 PM
check for endplay at the differential. The bushing I am talking about is where the yoke goes into the transmission. A leak usually is a telltale sign of that the same goes for the differential.
post #17 of 25 (permalink) Old 06-19-2006, 09:37 PM Thread Starter
MadGoat's Avatar
I just crawled under there to look again, I have no leaks... actually everything is bone dry... and looks like the day I installed it.
More and more im starting to think its that damn drive shaft. That might be the reason who ever I bought it from on here sold it.
Thanks so much for the info Alan... You just provided me with more information than 5 tech could and my DEALERSHIP! (scary thought).
Thanks again for the info and patience... I REALLY appreciate it.
MG
MadGoat's Birds
RIP
MadGoat is offline
post #18 of 25 (permalink) Old 06-19-2006, 09:40 PM
PostSkank
StupidFly's Avatar
Sorry to change the topic, bu I have to...
Garret..... Wife?!?!??!?
math > pasta
StupidFly is offline
post #19 of 25 (permalink) Old 06-19-2006, 09:46 PM Thread Starter
MadGoat's Avatar
Well The date is set and I have grown very tierd over these past three years of saying "FIANCE"... It sounds so snobb-ish to me...
So i figure its close enough now
MG
(well 2 1/2 going on three)
MadGoat's Birds
RIP
MadGoat is offline
post #20 of 25 (permalink) Old 06-20-2006, 01:54 AM
PostSkank
StupidFly's Avatar
I'll accept that as an answer. Grats! When we all get together again, dinners on me.
math > pasta
post #21 of 25 (permalink) Old 06-20-2006, 03:56 AM
hey what makes a trak-lok better then a open rear end and how do you know if you have one.
Jeff8705 is offline
post #22 of 25 (permalink) Old 06-20-2006, 07:21 AM
Traction lok will turn both wheels, open will turn whichever one has the leaset traction. There is a tag on the top cover bolt of your differential. Chances are you have an open,but if the tag says 3L27 in it you have a traction lok. Most of these diff are 308 so they will not have the L in them.
post #23 of 25 (permalink) Old 06-20-2006, 09:12 AM
girdnerg's Avatar
Thank you,
Rob
girdnerg is offline
post #24 of 25 (permalink) Old 06-20-2006, 08:47 PM Thread Starter
MadGoat's Avatar
ummm I dont think so,
Some very shine wheels on my car say that dinners on me!
MG
MadGoat's Birds
RIP
MadGoat is offline
post #25 of 25 (permalink) Old 06-20-2006, 10:46 PM
PostSkank
StupidFly's Avatar
MG
too-mufuggin-shay willis
math > pasta
