Swapping Tranny Entrails... - TCCoA Forums
post #1 of 15 (permalink) Old 06-19-2006, 01:43 PM Thread Starter
I have a J-Modded 94 4R70W in my T'Bird's "remains" ...
I will (eventually) be installing a AOD-E behind the 351C in my 73 Cougar...
Would the internals of the 4R70W be able to be installed in the AOD-E? (I'm mainly interested in the gear ratios)
Have I mentioned that automatic transmissions and trying to figure out what will and won't "fit" gives me a headache!!!
69 F100 LWB w/460 Engine
post #2 of 15 (permalink) Old 06-20-2006, 12:38 PM
The 4R gearset will swap dirrectly into the AODE case. I reccomend that you upgrade to the newest VB that will fit the case. I assume you are using a stand alone controler, so at that point I don't think electronics choice matters - not very clear on that point as I have not installed a computer of such yet.
Maybe you are considering a Manual VB, then it really doesn't matter what electronics are on the VB - and for all that matters you could use an AOD case and MVB.
When you do the swap just make sure you swap the ENTIRE gear train and bearings. The torrington bearings at the rear past the planet are specific to 4R70W.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #3 of 15 (permalink) Old 06-20-2006, 12:49 PM Thread Starter
Thanks.
I'm in the early stages of planning right now, so it's a long way off. But since I have the good 4R70W (and probably can't give it way, since it's a 94 case... ) I figured I would put it's innards to good use.
I'll be using the Baumannator TCS (tm) (http://www.becontrols.com/) to controll it since I have only heard very good things about them.
Thanks again for the reply... I was beginning to wonder if the resident tranny guru's were just ignoring me.
post #4 of 15 (permalink) Old 06-20-2006, 01:05 PM
It is our busy season...I have 5 trans sitting here at my shop. But only being a home builder with a day job and family...things just have to take time - which is good, but some days I wish I could work on my own **** for a change but.....it is my fualt I am swampped anyway, so I really can't complain.
You question is relitively old anyhow, that info can be found on many sites - but I still get the question about 2 a month. The swap is very easy as well.
As for using the 94 - yeah, it might be cheap and available, but I would highly suggest you put a MechOWC from a 98+ 4R and a truck dirrect drum - that Cleavland might out torque the 1994 4R components
IMHO, you should just invest in a 2000+ 4.2L 4R70W from the yard or new even. It will save you much time and money over trying to converter and upgrade. But don't take my word for it.....just saying
post #5 of 15 (permalink) Old 06-20-2006, 01:24 PM Thread Starter
My 94 is "supposed" to have the "goodies" from the tech article (mechanical diode, better accumulators, newer valvebody, etc.) so that's why I was leaning towards using those internals. I just don't remember the exact parts numbers. I'm pretty sure I just used the part numbers from the tech article. I know they tranny shop didn't do any machine work, but they hopefully installed all the new Ford parts I gave them.
I have a Paxton for the 351C (only planning 4 - 6 lbs boost), so I didn't think a 4R70W from the smaller engines (3.8/4.2L) would handle the torque.
But if they can be built to handle it, then I would VERY much prefer to just get the transmission and upgrade it without swapping internals to the AODE case.
post #6 of 15 (permalink) Old 06-21-2006, 08:31 AM
Yes, the 3.8 would have to be upgraded - but the 4.2 is pretty stout. Either way you would want to upgrade for a SC.
post #7 of 15 (permalink) Old 06-21-2006, 09:18 AM
I bet you will find the sun gear on that 94 transmission pretty mangled and it will likely need new bushings throughout.
post #8 of 15 (permalink) Old 06-21-2006, 01:02 PM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
Why a AOD-E? Why not just use a 3.8L/5.0L 4r70w Case and swap the internals or build up one?
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #9 of 15 (permalink) Old 06-21-2006, 01:06 PM
I'll venture a guess it's because the bolt pattern is different on the vast majority of 4rs out there... and the '94 internals are "free".
Sometimes, we just need to remember what the rules of life really are:
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
doodaa is offline
post #10 of 15 (permalink) Old 06-21-2006, 01:08 PM
WkStill's Avatar
But i don't beleive a newer VB will even fit an AOD-E Case.
And any 3.8L 4r will bolt to an old style 351C.. just won't last long without being beefed up.
1984 Merc Cougar
WkStill is offline
post #11 of 15 (permalink) Old 06-21-2006, 02:20 PM
you guys might be looking too shallow here....I am to assume that he has a BAD AZZ internals in the 94 4R and also has an AODE case to put them in - bing bang boom.
We could ***-u-me the tiny details all day long.
post #12 of 15 (permalink) Old 06-21-2006, 02:47 PM Thread Starter
Bingo!
I have access to cases all day long from my buddy that owns a transmission shop.
Thanks for all the feedback. I think what I'll do is open the case of the 94 4R70W and take a gander at the condition of the internals. Then based on the condition and type I'll then decide to go with a beefed up 4.2L 4R70W or put the free internals into a AOD-E case and just "run it and see".
The Cougar sees VERY little usage and if I grenade the transmission, it's not like I would be walking to work.
Thanks again for the info/suggestions.
post #13 of 15 (permalink) Old 06-22-2006, 12:10 PM
Yeah, but I bet that right foot gets a whole lot heavier in the Cougar. Not near as much fun romping down on the Aspire.
Just a thought but wasn't the 302/351 bolt pattern (and a pushrod V8) available in the Explorer up until like 99? Don't know if it was a 4r or 5r....
doodaa is offline
post #14 of 15 (permalink) Old 06-22-2006, 12:40 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Actually it was available through the 2001 model. I am pretty sure they did use the 4R70W.
tinman_72 is offline
post #15 of 15 (permalink) Old 06-22-2006, 01:20 PM
that is all true....the 5.0 4R was used till 01 - hard to come by, but worth having if you can find it. They swapped to the 4R/5r after that. Which is really too bad, since the 5R is a POS - I see more trouble with them than anything else....mainly cause SMALL internals in little case and people try to use the trans like a truck. FOrd should have kept the big trans in the explorer.
