MechDiode update and AOD piston - TCCoA Forums
post #1 of 3 (permalink) Old 06-21-2006, 12:30 PM Thread Starter
Yo trans builders....I show the AOD rev drum piston at .414" and the stamped steel AODE/4R rev drum piston at .494"
I am doing an update on an AOD, this time I ordered a new drum and it doesn't come stacked.
The seals are universal - so i assume I can use the AOD piston. I did order the piston kit with belvill and waved snap ring - BUT, could I have used the AOD piston - or would the belvill have been wrong and all that?
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #2 of 3 (permalink) Old 06-23-2006, 07:51 AM
I am pretty sure all of the internal stuff in the drum is the same.
post #3 of 3 (permalink) Old 06-23-2006, 10:59 AM Thread Starter
I have the parts, and I will check, but I assume you are correct as there is not different PN......the AOD one I pulled, the Belville was BROKE/split.
