Trac-Lock vs Torson - TCCoA Forums
post #1 of 10 (permalink) Old 06-26-2006, 11:22 PM Thread Starter
95_SilverBird's Avatar
Trac-Lock vs Torson
Just as the title says.. Can I get some opinions on the advantages / disadvantages of each. I've heard good things about Torson, but Trac-Lock sees to be the norm here. btw I'm looking to go 3.73's
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #2 of 10 (permalink) Old 06-27-2006, 09:39 AM
The advantage of 3.73's is you don't need a speedcal to correct your speedometer and your back road mpg won't be bad at all . Mine does great in the 55mph range, On the highway it will suffer a little. 4.10's aren't much different except I find they still lose mpg in the 55mpg range. On the highway they get slightly worse. and you need a speedcal. I don't honestly care for the torsion differentials only because of the torsion gm's I have seen explode. You can overstack the stock traction lock to get an extra plate in each side, then pack it tighter than stock. Thats my chioce of setup for most applications.
I have built a couple of detroit truetrac's they seem like a good setup.
post #3 of 10 (permalink) Old 06-27-2006, 04:03 PM
for street and even mild performance strip action the OEM traklok is definetly capable when stacked correct and good fluid is used.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #4 of 10 (permalink) Old 06-27-2006, 11:18 PM Thread Starter
Thanks for the input - maybe I'll get a trac-lock after all.
post #5 of 10 (permalink) Old 06-27-2006, 11:45 PM
Refrigerator Raider Hater
GreenBird's Avatar
I'd have some input on the torsen, but Don hasn't finished building it yet.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 10 (permalink) Old 06-28-2006, 09:25 AM
I've got the Torsen T2 and it locks up really hard and has taken lots of beatings...
Mine is actually so tight that when I reverse and turn the wheel max it
starts to lock up....
The main reason for me to get the Torsen T2 was that it doesn't have clutches,
I like the design idea and from recommendations...
But it's not an easy choice.. buth have advantages and disadvantages...
//Per
Thyg0d is offline
post #7 of 10 (permalink) Old 06-29-2006, 10:07 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
A general rule of thumb I've heard since the Torsen came out was that the Ford Trac-Loc is what you want for street/strip and the torsen is much more suited to street/road course/autocross.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #8 of 10 (permalink) Old 06-30-2006, 02:15 PM Thread Starter
Will this screw up my shift points enough where I need a chip or is this more or less a plug and play?
post #9 of 10 (permalink) Old 06-30-2006, 02:30 PM
did you just say that............
post #10 of 10 (permalink) Old 06-30-2006, 02:50 PM Thread Starter
Yes... I'm an idiot... But I thought I remembered both being mentioned just can't remember whats accurate and was to lazy to search. (now running to hide)
