quickie on MLPS please - TCCoA Forums
post #1 of 4 (permalink) Old 06-28-2006, 10:23 AM Thread Starter
baylensman's Avatar
Send a message via AIM to baylensman
did a search on alldata for MPLS on 97 cougar no such listing.
is the MLPS called by another name such as
"Transmission Position Switch/Sensor"
"Shift Interlock Switch" or
"Transmission Mode Switch"
these are the three trans related swithcesother than the speed sensor and temp sensor i found in the 97 cougar diagram
the tps is the only one located need the trans the other er are on the steering column and under the dash.
Is the "TPS" the same as the MLPS?
i'd rather go slow than not go at all
1996 MKVIII air ride delete
2007 Royal star venture (loaded)
2007 Ford free style 3.0 v-6
baylensman is offline
post #2 of 4 (permalink) Old 06-28-2006, 11:25 AM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
It's MLPS (Manual Lever Position Sensor).
AKA Neutral Safety Switch.
And the TPS (Throttle Position Sensor) is located on the throttle body....
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #3 of 4 (permalink) Old 06-28-2006, 01:44 PM
JustinH's Avatar
ford sometimes calls it a transmission range sensor
JustinH is offline
post #4 of 4 (permalink) Old 07-06-2006, 10:15 PM
3rd Gear Chirper
hotbird's Avatar
Gotta love NoData.
It's one of those two.
hotbird is offline
