Tranny Question? - TCCoA Forums
post #1 of 9 (permalink) Old 07-11-2006, 08:17 PM Thread Starter
Tranny Question?
I had my tranny built a little over a year ago, and it works good except for sometimes when I WOT when I hit second gear it will drop the gear and rev, and when the RPMs start to drop it will grab! I took it to the shop the did the rebuild and they got it to act op finally after taking back there like 5 times, and they said its not the tranny it has something to do with the electrical. They said it my be my TPS sensor. Will that damn think affect the tranny or are they a bunch of F**kin idiots!
p_mcnaught is offline
post #2 of 9 (permalink) Old 07-11-2006, 10:52 PM
Could be the MPLS acting up. My 95 did that before. Of course what stopped mine was replacing the 1-2 accumulator during the j-mod. No more rev/bang into 2nd, just chirp.
Jay
FordMan77 is offline
post #3 of 9 (permalink) Old 07-11-2006, 10:58 PM Thread Starter
They replaced the MLPS when they did the rebuild cause the other one was bad! What parts are needed to do the J-Mod? any part #'s?
post #4 of 9 (permalink) Old 07-11-2006, 11:19 PM
Darrin's Avatar
I bet I know what it is and its not good. Do a search on intermediate one way clutch. You have the roller style and its about to blow up. Looks like its past time to start saving for a newer trans.
Sorry to be the bearer of that bad news.
Darrin
Darrin is offline
post #5 of 9 (permalink) Old 07-12-2006, 10:04 AM Thread Starter
All the clutches are new, when my tranny blew the first time this snap ring busted and all the clutches blew out, they showed me all the parts they were all black and burnt up! What sucks also is my warranty on the tranny was up 2 months ago! also when I am driving normal keeping the rpm no higher than 3000, it works perfectly fine!
post #6 of 9 (permalink) Old 07-12-2006, 12:17 PM
Darrin's Avatar
See, that one way roller clutch is not a clutch as you are thinking. Its a completely different kind of clutch. It doesn't burn up because it is made from roller bearings that ride in a ramp to allow it to turn in one direction and not in the other. Some people call this setup a sprag. They never should have put that setup in these transmissions. The one you have is the weakest of them all and I killed one on a 3.8 car. They just cannot handle what they are supposed to.
What has happened is that you have taken it through too many WOT shifts. What is happening is that it is falling apart. What will happen is that you will eventually completely lose 2nd gear.
Until you can get it replaced you need to completely baby that car through the 1-2 shift. I am still running on the one in my 97 and I am waiting for it to completely grenade. Its been like that for months now. The good thing is that it keeps my foot off the floor and I am getting better city mileage. LOL
DO NOT pay someone to rebuild that transmission again. You will end up in exactly the same situation as you are now if you do. You need to get a whole new transmission to get rid of this problem.
Trust me on this. This is what I do. Ask around.
Darrin
Darrin is offline
post #7 of 9 (permalink) Old 07-12-2006, 12:48 PM
raven's Avatar
I knew someone that had a similiar problem on a VW Jetta. They did a road test with some kind of computer hooked up. It showed that everytime the tps voltage would jump, the transmission would act up. VW dealer said it was common for those to go bad. Don't know if you are having the same problem but a new TPS sensor for a Tbird is only around $35. Might be worth a shot. Also make sure your battery and charging system are good.
"You know Darren, if you would have told me twenty-five years ago that some day I'd be standing here about to solve the world's energy problems, I would've said you're crazy... Now let's push this giant ball of oil out the window." Cosmo Kramer
raven is offline
post #8 of 9 (permalink) Old 07-12-2006, 12:58 PM Thread Starter
Thanks darrin, I think I will have Kdanner build me one in a couple of months!
post #9 of 9 (permalink) Old 07-12-2006, 01:07 PM Thread Starter
Is the sprag a round piece that looks like a sproket in a way? If it is and its the right picture I saw that was the piece that failed! What I think they did they just rebuilt it cause if I remember correctly they said it would cost alot for to put a new one in there! Email me darrin @ [email protected]. After I write this I wont be online in a while. I am having my monitor shipped back to HP to get fixed! Email me so I can send you pics of what part I think might be what you are talking about!
