RPM Change in 3rd - TCCoA Forums
post #1 of 12 (permalink) Old 07-14-2006, 08:43 AM Thread Starter
The Stevinator's Avatar
RPM Change in 3rd
When my tranny shifts into third it drops to 1k RPM (and sounds like it's barely chugging along), and I have to practically go WOT to get it where it jumps back up to normal range. Anyone know what a cause of this could be (all fluids are clean and up to level, and the TC was replaced (with stock) about 2 months ago.).
The Stevinator is offline
post #2 of 12 (permalink) Old 07-14-2006, 09:21 AM
Darrin's Avatar
Could be that the TPS needs to be checked for proper voltage and that it doesn't have any dead spots.
Darrin
Darrin is offline
post #3 of 12 (permalink) Old 07-14-2006, 11:44 AM Thread Starter
Dead Spot. so they can go out in certain positions of the TPS. I thought they went out all together.
post #4 of 12 (permalink) Old 07-14-2006, 12:44 PM
Darrin's Avatar
No, its a variable resistor. Have you ever had a volume control that got noisy or only worked in certain places?
I am not saying that this is the problem at all, but its a possibility. What is the TPS voltage at idle?
Darrin
Darrin is offline
post #5 of 12 (permalink) Old 07-14-2006, 12:45 PM Thread Starter
not sure, i would have to check after work. could it have anything to do with the lock up solenoid?
post #6 of 12 (permalink) Old 07-14-2006, 12:54 PM Thread Starter
what should the voltage be at idle be?
post #7 of 12 (permalink) Old 07-14-2006, 01:03 PM
Darrin's Avatar
voltage at idle should be really close to or at 1v. I set mine to .98v. The TPS being off will give the computer false information on the throttle position and the computer controls the TCC based partly on that.
Again, this may have nothing at all to do with your problem, I am just throwing out one idea.
If you had a data logger then I could tell you a lot more.
Darrin
Darrin is offline
post #8 of 12 (permalink) Old 07-14-2006, 06:29 PM Thread Starter
well looks like the tps is in good shape. im starting to think its the lock up solenoid now. i had to replace it when i replaced the torque converter, but it didn't get rid of the CEL it threw. so im guessing its bad wiring on the solenoid.
post #9 of 12 (permalink) Old 07-14-2006, 06:48 PM
Darrin's Avatar
You need to find someone with an xcal2 and datalog that thing to see when the TCC is being commanded. It sounds like its doing what its told to be doing but is being told wrong.
Darrin
Darrin is offline
post #10 of 12 (permalink) Old 07-14-2006, 07:03 PM Thread Starter
interesting. hate to make you type it out. but say i do datalog it. what exactly would i be looking for?
post #11 of 12 (permalink) Old 07-14-2006, 07:11 PM Thread Starter
oh yeah, im OBD I. any other tuners that can datalog this sucker?
post #12 of 12 (permalink) Old 07-14-2006, 08:18 PM
Darrin's Avatar
the diablo predator might be able to
You want to log TCC commanded duty cycle.
Darrin
Darrin is offline
