8.8" rear end... - TCCoA Forums
post #1 of 24 (permalink) Old 07-15-2006, 04:51 PM Thread Starter
JL2K7388's Avatar
Send a message via AIM to JL2K7388
8.8" rear end...
i have a 96 3.8 which came stock with the 7.5" inch open diff is it worth upgrading to an 8.8 differential because either way i plan on going trac-lok with 3.73's. Also if it really is worth swapping out my entire rear is it possible to use the complete 8.8 rear from a stang that came with trac-lok and 3.73's from the factory or no?? thanks
96 LX 3.8
Custom air intake, 9" K&N Cone, ASP underdrive pulleys, True Duals with DI/DO midmounted Magnaflow, ported upper and lower intakes, ported TB...and more to come
http://www.cardomain.com/ride/2385772
-Johnny-
JL2K7388 is offline
post #2 of 24 (permalink) Old 07-15-2006, 05:03 PM
94thunderchicken's Avatar
mustang 8.8 wont work becuase it is solid axle. you can make your own custom 4 link setup back there to accomodate the solid axle but i wouldnt do it. i'd just build what you got or get an 8.8 IRS from a v-8 bird. just my .02.
94 lx : sold
94thunderchicken is offline
post #3 of 24 (permalink) Old 07-15-2006, 05:12 PM Thread Starter
JL2K7388's Avatar
ohh yeah i remember hearing that now it rings a bell thanks alot, but also is the 8.8 a great deal better than the 7.5 to go through the trouble?? thanks
96 LX 3.8
-Johnny-
JL2K7388 is offline
post #4 of 24 (permalink) Old 07-15-2006, 05:13 PM
strength wise yes the 8.8 is better of the 2
94 lx : sold
post #5 of 24 (permalink) Old 07-15-2006, 10:24 PM
No Stangs came from the factory with 3.73s and traction lok in a 8.8 anyway. might as well just build one.
Decy is offline
post #6 of 24 (permalink) Old 07-15-2006, 11:29 PM
some prototpye's came with 3.73's factory. even though my 84 predator was built after the factory, it was ordered with 3.73 trac lock 8.8 rear end and had a 306 in it. some cars could be ordered that way, depended on how the owner wanted it built before they made the car.
94 lx : sold
post #7 of 24 (permalink) Old 07-15-2006, 11:42 PM
heres what gears they either came with or could be ordered with 79-93
all depends on what the axle code is on the door sticker
94 lx : sold
post #8 of 24 (permalink) Old 07-16-2006, 07:23 AM
Rangers often came with 3.73's and some of them had traction lock.
post #9 of 24 (permalink) Old 07-16-2006, 08:17 AM
The 8.8 is definitely the way to go. Just do yourself a favor and find a frpp centersection it already has 3.73s and trac lok. And its no trouble swapping you can have the centersections changed in a few hours. If you cant find an frpp pumpkin find one from a mark viii-theyre aluminum, and just have the parts installed in that.
teal944.6 is offline
post #10 of 24 (permalink) Old 07-16-2006, 12:03 PM
Does your door sticker have a "W" for the axle code? I'd like to see it, because it would be the first one I've ever seen in a Mustang. I've seen lots of Mustangs with axle code "6" (3.73 open) but they were four-bangers with automatics and 7.5 rears. I've seen lots of Fox T-Birds with "W" codes but those weren't Mustangs. Lots of Rangers and most older Explorers came with 3.73s and traction lok. Even the list you showed says it's generic and just because a code is listed it doesn't mean it was available in a Mustang.
Decy is offline
post #11 of 24 (permalink) Old 07-16-2006, 12:13 PM
The Great Obucina's Avatar
the FRPP diff is no longer made.
"Booyah". Stu Scott.
The Great Obucina is offline
post #12 of 24 (permalink) Old 07-16-2006, 12:14 PM
you cant four link a unibody without completely backhalving it.
post #13 of 24 (permalink) Old 07-16-2006, 01:08 PM
Thats why i mentioned the mark viii pumpkin arent those of aluminum construction as well?
post #14 of 24 (permalink) Old 07-16-2006, 01:14 PM
thats what i meant to say the first time but it came out wrong, my bad
94 lx : sold
post #15 of 24 (permalink) Old 07-16-2006, 01:24 PM
if you would have read my post a little better you would have seen that i said "it was built after the factory". my 84 Predator came with 3.08 trac-lock and a 7.5" rear from the ford plant in dearborn, MI. you need to read up on the predator mustang if you havent before, you would see that they can be ordered with any engine modifications and your choice of rearend. i never said once that it came from ford that way. i've seen people go through the trouble just to get a door sticker that says it has a trac-lock 3.73 from the factory, but it isnt a "true" trac-lock car. so yes your right on one thing that the mustang from the ford factory didnt come with 3.73 trac-lock rearend, but it could be ordered to be installed after the owner purchased it. sorry if i worded it wrong, but this is what i meant.
94 lx : sold
post #16 of 24 (permalink) Old 07-17-2006, 01:53 AM
My only point all along was that NO MUSTANG CAME WITH 3.73S AND TRACTION LOK IN A 8.8 REAR FROM THE FACTORY. I don't care what could be ordered aftermarket from Predator, Saleen, Roush or whoever. Anybody could get gears installed at shops everywhere. The original poster had the assumption that Mustangs came with this ratio from the Ford Factory. I only pointed out that they didn't. I'm sure it's possible that prototypes did get 3.73s, but prototypes weren't available for sale to the public. I've heard of Predator. Don't care. I've seen plenty of Saleen, ASC McLaren, and Roush Mustangs. Don't care either.
Decy is offline
post #17 of 24 (permalink) Old 07-18-2006, 06:52 PM
IRS Case
Does anyone know if an aluminum IRS case from a late Explorer is the same as a '95 Thunderbird LX? The T-Bird has an 8.8 cast iron case. Thanks
danielbal is offline
post #18 of 24 (permalink) Old 07-18-2006, 07:58 PM
No explorer cases are not the same
post #19 of 24 (permalink) Old 07-21-2006, 07:32 AM
4.3Lcougar's Avatar
if your going through the trouble of a 8.8" swap make sure to grab the half shafts too! they are much stronger the the weak 7.5's
4.3Lcougar is offline
post #20 of 24 (permalink) Old 07-21-2006, 08:54 AM
Can you show us pictures of the different chafts. I know of 3 different productin halfshaft. The markVIII ones, SC fat shafts and everything else.
post #21 of 24 (permalink) Old 07-21-2006, 09:13 AM
Who is John Galt?
If he's not going to anything spectacular (power-wise) right now, I'd say just stick with the V6 halfshafts. The bigger shafts are just more weight that the engine has to move.
"Won't work, can't be done"
cougar_guy04 is offline
post #22 of 24 (permalink) Old 08-03-2006, 03:02 PM
Potential of the SC Shafts?
What kind of power can these 'fat' SC halfshafts handle? I'm ripping out the rear from an SC and I'm curious about what I can throw at it after I put these halfshafts in as well.
FordofSin is offline
post #23 of 24 (permalink) Old 08-03-2006, 03:08 PM
"Rangers often came with 3.73's and some of them had traction lock.
Alan"
Really! I am gonna look for one of them. Do you know the codes? Or would it be the same as the ones on the diff code list?
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #24 of 24 (permalink) Old 08-03-2006, 04:34 PM
The diff will have a 3L73 tag on it.
