3:55 Or 3:73? - TCCoA Forums
post #1 of 16 (permalink) Old 07-16-2006, 12:19 AM Thread Starter
gcash81001's Avatar
Send a message via AIM to gcash81001 Send a message via MSN to gcash81001
3:55 Or 3:73?
How do they behave on the road and highway. I have got a great deal on a complete pumpkin with 3:55 but I wanted 3:73's. Should I go with the 55's or 73's?
gcash81001 is offline
post #2 of 16 (permalink) Old 07-16-2006, 01:19 AM
I assume the 3.55 pumpkin is a trac-loc?
Depends on how much highway driving you do. IIRC, the 3.55's will be better on gas mileage (duh) than the 3.73's. But the 3.73's from what I've heard really wake these cars up.
For my money and since the bird will not be a daily driver I'm going with a 3.73 trac-loc unit. I don't really care if it kills the mileage. I've got to do something to compensate for the 95 motor, lol... Oh and before I forget I think know you have to change the speedo gear in order to keep it accurate based on the ratio you go with, so keep that in mind as well.
Jay
FordMan77 is offline
post #3 of 16 (permalink) Old 07-16-2006, 07:07 PM Thread Starter
gcash81001's Avatar
well the car is a daily driver so, the 3:55's would help right, is it worth it? Btw, the 3:55 pumpkin is a trac-loc
post #4 of 16 (permalink) Old 07-16-2006, 07:31 PM
Yes, the 3.55's would be a definite improvement over the open 3.08's your car probably has now. I guess the debate is what plans do you have for your car in the future? Is it going to stay mostly stock, or going w/ a PI swap or something to that extreme?
If you plan on upgrading a bunch of stuff then I personally would go w/ the 3.73 trac-loc. I would not want to spend all that money on a 3.55 TL + setup/install fees just to replace it a year later w/ 3.73's. Not real economic. I'd say do a quick search and see what other guys have done.
Jay
post #5 of 16 (permalink) Old 07-16-2006, 08:36 PM
4.30's. no less.
post #6 of 16 (permalink) Old 07-16-2006, 08:37 PM Thread Starter
gcash81001's Avatar
yeah, I plan on build up a PI motor is the near future, I wish to shot for 260-300 hp range.
post #7 of 16 (permalink) Old 07-16-2006, 10:28 PM
Well you can get the complete pumpkin, so install will not be expensive. I say put in the 3.55s and see if you like them or not. If you still want the 3.73s, start looking for them and sell the 3.55s.
Mike
post #8 of 16 (permalink) Old 07-17-2006, 12:33 AM
90 sc 460's Avatar
Go to a pick-a-part like I am and get 2 whole differnitals . They swap in easy(kind of)
90 sc 460 is offline
post #9 of 16 (permalink) Old 07-17-2006, 01:00 AM
5.0 bird's Avatar
Send a message via MSN to 5.0 bird
With the 3.55s I get 26 mpg hwy running 80-85 mph at 24-2500 rpms. At 70 it runs at 2200 rpms. They work for me since I spend some time on the hwy. They also help this car get up off it's fat @ss compared to 3.08s It really just boils down to what you wanna do with the car. If you can get the 3.55 center section cheap and it's a trac-lok I'd do it since it just goes back in.
Matt
1986 Cougar 5.0
1989 Mk VII LSC 5 speed (sold)
1992 Thunderbird Sport 5.0 (sold)
5.0 bird is offline
post #10 of 16 (permalink) Old 07-17-2006, 04:50 PM
girdnerg's Avatar
Originally Posted by gcash81001
...I have got a great deal on a complete pumpkin with 3:55...
Originally Posted by MadMikeyL
Well you can get the complete pumpkin, so install will not be expensive. I say put in the 3.55s and see if you like them or not...
I'd also suggest the 3.55s because if you go with 3.73s you will also have to have a chip/tune to compensate for the new gears or the car won't shift right.
You can go 2 steps in either direction without having to chip/tune it.
3.08->3.27->3.55 = 2 steps.
3.55s = great deal (according to your post) and the price of the proper tranny speedo gear.
3.73s = price of gears/pumpkin/setup/proper speedo gear/etc. and a chip/tune.
Rob
girdnerg is offline
post #11 of 16 (permalink) Old 07-17-2006, 05:45 PM
VicRattlehead's Avatar
buy my 4.56's
CMP Drag Racing
VicRattlehead is offline
post #12 of 16 (permalink) Old 07-17-2006, 06:01 PM
Traveler's Avatar
Originally Posted by girdnerg
........3.55s = great deal (according to your post) and the price of the proper tranny speedo gear.....
Rob
So just what is the proper speedo gear for 3.55's? I plan on installing a set as soon as I can get the rear end built. (still saving up for the rebuild kits, and labor on the rebuild)
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #13 of 16 (permalink) Old 07-17-2006, 08:21 PM
Originally Posted by VicRattlehead
buy my 4.56's
hom much?
Throw me a PM.
post #14 of 16 (permalink) Old 07-17-2006, 08:32 PM
Rob
Oh NO,
I have stock 3.27 open, do I need to get a chip? Eric
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #15 of 16 (permalink) Old 07-17-2006, 08:49 PM
Originally Posted by _95badbird
hom much?
Throw me a PM.
you cant have em
CMP Drag Racing
post #16 of 16 (permalink) Old 07-17-2006, 09:13 PM
you cant have em
b1tch
