Darrin, Lonnie - TCCoA Forums
post #1 of 25 (permalink) Old 07-21-2006, 12:41 PM Thread Starter
Darrin, Lonnie
Is there anything you do in your EEC tuning to help the trans on the 3-4 shift?
Mitch
MitchB is offline
post #2 of 25 (permalink) Old 07-21-2006, 01:57 PM
95xbird's Avatar
careful on your 3-4 shift.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #3 of 25 (permalink) Old 07-21-2006, 02:52 PM
if your going to tell him to be careful, at least give a reason.
post #4 of 25 (permalink) Old 07-21-2006, 03:06 PM
95xbird's Avatar
overdrive bands are easy to destroy.well at least in the 4R70W it is.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #5 of 25 (permalink) Old 07-21-2006, 03:11 PM
exactly.
BTW, I wasn't tryin to be rude or anything
post #6 of 25 (permalink) Old 07-21-2006, 03:17 PM
95xbird's Avatar
Originally Posted by _95badbird
exactly.
yes you were!
Its slow, Really.
LS1 KILLER
95xbird is offline
post #7 of 25 (permalink) Old 07-21-2006, 03:21 PM
yes you were!
well okay, maybe I was
post #8 of 25 (permalink) Old 07-21-2006, 06:50 PM
Darrin's Avatar
Thats fine and all, but the problem on the 3-4 shift isn't the overdrive band. Its a thing called an intermediate stub shaft. Fix that with a hardened shaft and you have to deal with the splines that it goes into on the direct and forward hubs.
Its a matter of hard parts breakage. That is bad
Darrin
Darrin is offline
post #9 of 25 (permalink) Old 07-21-2006, 07:28 PM
run the car in the 1/8 mile ...never hit 4th...lol just my plans
C F I FLY is offline
post #10 of 25 (permalink) Old 07-21-2006, 07:48 PM
driller's Avatar
You hit 4th in the 1/4 mile?!
driller is offline
post #11 of 25 (permalink) Old 07-21-2006, 07:52 PM
trying to get my bird for the 1/8 mile track ...nearest 1/4 is 100 miles each way but have 2 tracks within 30 miles from home
post #12 of 25 (permalink) Old 07-24-2006, 12:12 AM Thread Starter
Well, what I was really looking for is if anyone uses torque reduction on the 3-4 shift. I do. I reduce torque by as much as 40%.
Mitch
MitchB is offline
post #13 of 25 (permalink) Old 07-24-2006, 08:48 AM
Darrin's Avatar
That won't help. The problem is greater than that. You can easily break these parts with a stock 3.8 using torque reduction when the wrong thing happens at the wrong time. Which eventually will happen.
Darrin
Darrin is offline
post #14 of 25 (permalink) Old 07-24-2006, 09:23 AM
Toombs's Avatar
From what I understand, the problem comes from the inability to effectively exhaust the forward clutch at higher RPM......is this accurate Darrin? If so, are there any measures that can be taken to aid in exhausting this clutch drum? Just thinking out loud here...I know we modify turbo 400s for quicker exhausting for use with trans-brakes. Could something similar be done here?
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #15 of 25 (permalink) Old 07-24-2006, 10:53 AM Thread Starter
Darrin
Can you be more specific?
Mitch
MitchB is offline
post #16 of 25 (permalink) Old 07-24-2006, 12:04 PM
Darrin's Avatar
http://www.tccoa.com/articles/tranny...on/index.shtml
Darrin is offline
post #17 of 25 (permalink) Old 07-24-2006, 12:48 PM
Toombs's Avatar
The OD servo and the forward clutch exhaust through the same orifice, so anything that would make the forward clutch exhaust quicker also would make the servo apply the band quicker......which gets you no closer to solving the problem.
Am I interpreting that correctly?
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #18 of 25 (permalink) Old 07-24-2006, 03:26 PM Thread Starter
Darrin, I pretty much understand the dynamics and issues involved in the 3-4 shift. My point here is - if you have the trans setup to execute this shift as good as possible, reducing the max torque allowed on the 3-4 along with some other things will reduce the failure rate. Of course, things can go wrong and you'll end up breaking something, but that's not what I'm talking about.
Mitch
MitchB is offline
post #19 of 25 (permalink) Old 07-24-2006, 04:22 PM
Darrin's Avatar
Sorry Mitch,
With all the torque reduction in the world, your engine and torque converter still have enough rotational mass to snap and destroy things when the time comes that something doesn't happen when it should.
I thihnk it was JL that broke stuff with his foot coming out of the throttle and getting a 3-4 by accident.
My best advice is still going to be to read more of that link I gave you. But, unfortunately it sounds like you have your mind made up already. The post started out as a question about the EEC and I tried to explain how it doesn't matter. Perhaps that is where I made my mistake.
So, I will try to more exactly answer your question. The answer is yes. Set the 3-4 WOT shift to 127mph. That absolutely WILL help protect the transmission.
I hope that helps
Darrin
Darrin is offline
post #20 of 25 (permalink) Old 07-24-2006, 07:39 PM Thread Starter
Sorry Mitch,
I hope that helps
Darrin
Darrin, my question was helping the 3-4 shift under normal conditions, not under extreme conditions or when something goes awry. With regard to the JL failure, I have one question. At what RPM did this happen? Rotational inertia is only one part of this failure and probably the minor one.
Incidentally, I had a relatively long discussion with Jerry about the 3-4 shift on high power cars before he wrote that article. In fact, I have a hard copy that he sent to me before it appeared here on the TCCoA.
Mitch
MitchB is offline
post #21 of 25 (permalink) Old 07-24-2006, 08:51 PM
Darrin's Avatar
So I just now am left with only one question.
Since you have explained your position and what you do for this issue and have talked with Jerry himself then why are you asking us? It seems like you had your answers from the start and this should have been less of a question and more of an informational commentary. Just saying.
My idea now would be for you to come back and tell us how it works out for you. After a very lengthy testing period of course.
I wish you great success.
Darrin
Darrin is offline
post #22 of 25 (permalink) Old 07-24-2006, 09:15 PM Thread Starter
Darrin
Our discussion was long before EEC calibration became the topic of every day discussion. What we did discuss was the trans main control calibration and the issues involved with the trans itself, not primarily EEC calibration. That is why I posed the question. I don't have a definitive answer. I did tell you one of the things I do, however. If I understand your response, your saying the 3-4 shift can trash the trans at almost any time and there is really nothing that can be done to help the 3-4 shift.
Mitch
MitchB is offline
post #23 of 25 (permalink) Old 07-24-2006, 10:07 PM
Darrin's Avatar
That is not what I am saying at all. Where did you get that? The problem on the 3-4 occurs at high TP and high rpm shifts.
Can you perhaps be very specific about what you are asking. As I just said, the problem that I know of on 3-4 shifts is at high TP or high rpm where the forward clutch can not exhaust fast enough and creates an issue when the OD band comes on.
At normal TP and reasonable rpm's this is not an issue. Things can happen in the alloted time and everybody is happy.
What I am saying is that if the shift happens under one of the conditions that causes the 3-4 shift problem then you cannot reduce torque enough to fix it and if you are reducing torque to fix a problem under conditions in which it doesn't really exist, then...
Well... Please tell me what you are really asking.
Darrin
Darrin is offline
post #24 of 25 (permalink) Old 07-24-2006, 10:40 PM
Darrin's Avatar
There is a point that I just thought of. Ford put TR in the abilities of the computer on purpose and the computer has that ability for that shift. Don't you think if it needed more TR to make the trans last then perhaps they would have done that from the factory? Their factory calibrations are all about making every part of the vehicle last that they possibly can.
Just a thought
Darrin
Darrin is offline
post #25 of 25 (permalink) Old 07-25-2006, 07:48 AM
Whining Intakes Rock
Al_Florida's Avatar
The consequence of a 3-4 WOT shift:
http://forums.tccoa.com/showthread.php?t=67549
# 0 rows returned
# drop table users;_
Al_Florida is offline
