what tranny in 5.0 - TCCoA Forums
post #1 of 11 (permalink) Old 07-24-2006, 05:31 AM Thread Starter
what tranny in 5.0
i had my tranny recently rebuilt but i was wondering what kinda of tranny comes in the 5.0 and can it hold 400hp with out any major problems.
TroyN is offline
post #2 of 11 (permalink) Old 07-24-2006, 07:44 AM
I can't answer the second part of the question, but you have an AOD.
post #3 of 11 (permalink) Old 07-24-2006, 07:56 AM
MaddMartigan's Avatar
Like already said, it's an AOD.
Nope, it won't hold 400hp. It's going to cost you between $1800 and $2500 to get an AOD that will hold up to that.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #4 of 11 (permalink) Old 07-24-2006, 10:02 AM
I disagree.......400hp is easy, and teh AOD holds well up to 600. After 500 I suggest 4R70W upgrade.
Stick with your AOD depending on what you do with the car.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #5 of 11 (permalink) Old 07-24-2006, 10:26 AM
So the 4R70W is rated to 700 foot pounds of torque. What type of torque multiplication do you get when the torque converter isn't locked?
And I don't know what this has to do with your AOD, but I do know that is what the 70 in 4R70W stands for.
Bangster is offline
post #6 of 11 (permalink) Old 07-24-2006, 11:21 AM
You're right. I don't know what I was thinking. dirtyd0g is such a liar.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #7 of 11 (permalink) Old 07-24-2006, 11:30 AM
What I mean is you make 400 sound like a chore for the AOD....however you are correct, it will cost some money.
post #8 of 11 (permalink) Old 07-24-2006, 06:23 PM Thread Starter
so what you guys are saying is that my aod isnt capalbe of holding 400hp is that correct
TroyN is offline
post #9 of 11 (permalink) Old 07-24-2006, 06:38 PM
That is correct.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #10 of 11 (permalink) Old 07-25-2006, 04:54 AM Thread Starter
so then the next question arises what can it hold... and what would i want to put in for a 500pony car that could definetly have no problems
TroyN is offline
post #11 of 11 (permalink) Old 07-25-2006, 05:12 AM
Well, there are a couple of good choices that I am aware of. You can contact dirtyd0g on here and see if he would be willing to hook you up. He built mine and we put the strongest stuff that can be had in mine. The other option is to check out Lentech and pick one up from them. They seem to offer a pretty good option as well. You can find out more from here: http://www.lentechautomatics.com/aodhome.html
The goal here is to get one that you can put in and forget it. You will also want an appropriate torque converter along with it. The stock converter just won't cut it so you'll want to make sure you budget for that.
You'll find that Lentech is probably more expensive than dirtyd0g (Alan). The Lentech you'll want to start with is the Street Bruiser at least.
Good luck.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
