4.30s in - TCCoA Forums
post #1 of 9 (permalink) Old 07-30-2006, 05:32 PM Thread Starter
driller's Avatar
4.30s in
Well, thanks to dirtydog, the 4.30s are finally in.
I took the opportunity of access to the lift to install front suspension braces...
and new brakes.
It was not without incident however. After 2 rounds of breaking in the new gears, I proceeded on the long trek home. About 50 miles out a terrible vibration started from the rear. Nursing the ailing car back to the shop, I was convinced it wasn't the new gears but perhaps a failing wheel bearing. Once finally back to the shop, it didn't take long to find the culprit. Apparently one of the rear rotors was not drilled/chamfered properly not allowing the rotor to seat on the hub! As a matter of fact, the wheel studs were forced slightly back from mounting the tire and two had broken from the stress. After chamfering the rotor backside for clearance and installing new studs, the brake assembly was replaced and the wheel installed without any problems.
Thanks Alan!
driller is offline
post #2 of 9 (permalink) Old 07-30-2006, 06:05 PM
You are most certainly welcome, I'm sorry john's head got in that last pic
The car was a pleasure to work with as you to deal with. Most people would have become frustrated with the first incident having Summit send me the wrong spline and me not paying enough attention to check it. You can bet I'll be checking them immediately from now on. Have you checked to see how well it connects both wheels yet? That setup doesn't make sense to me as to how it drives both wheels,when obviously on the lift it acts like a open differential.
Thanks John
post #3 of 9 (permalink) Old 07-30-2006, 08:42 PM Thread Starter
driller's Avatar
Oh, they hook alright.
All I know is the Trutrac performs open until needed. Torque is somehow transferred to the wheel that is not spinning by the gear action in the differential from the spinning wheel.
driller is offline
post #4 of 9 (permalink) Old 07-30-2006, 08:49 PM
Marl's Avatar
Send a message via AIM to Marl Send a message via Yahoo to Marl
I like the setup in the rear end. It looks like it will be super strong!
1995 4.6L XR7 Dual Guage Pod with Oil and Temp., 255/60R15 Yokohama Avid S/T's, Screamin' Demon Coil's with Live Wires, K & N, modified stock oil pressure gauge, air silencer removed, stock air box, trans and tune by Darrin, TC by Dirtydog
Sometimes when I reflect back on all the beer I drink I feel ashamed. Then I look into the glass and think about the workers in the brewery and all of their hopes and dreams. If I didn't drink this beer, they might be out of work and their dreams would be shattered. Then I say to myself, 'It is better that I drink this beer and let their dreams come true than to be selfish and worry about my liver.'
Spend your money on your ride and not your girl. It'll last longer and fewer people have been in it!
Marl is offline
post #5 of 9 (permalink) Old 07-30-2006, 09:30 PM
(homer simpson)mmmmm, 4.30's(homer simpson)
post #6 of 9 (permalink) Old 07-30-2006, 10:11 PM
VicRattlehead's Avatar
i wanna spool
VicRattlehead is offline
post #7 of 9 (permalink) Old 07-30-2006, 10:21 PM
The somehow is what baffles me. The sidegear is essentially a sun gear and the planetary gears connect to it,but from there they connect to nothing, just doesn't make sense to me.
post #8 of 9 (permalink) Old 07-30-2006, 10:34 PM Thread Starter
driller's Avatar
At least I don't hafta understand it to male it work!
driller is offline
post #9 of 9 (permalink) Old 08-03-2006, 12:39 AM
Icarus's Avatar
Torsen Tech article (PDF)
Torsen diff (mainly Audi related but decent info)
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
