Half shafts - TCCoA Forums
post #1 of 13 (permalink) Old 07-31-2006, 05:08 PM Thread Starter
Half shafts
It has come to my attention that the stock or OEM half shafts on our cars don't like the 300+ HP mark. Is the SC half shaft switch worth the trouble? Or would looking at the RAXLES half shaft be a better buy? I don't want to just go to the 2003 cobra swap because of the hasle of getting 31 spline spindles. Does anyone have a set up that works for them? I figure that I should look in to beefin up everything prior to puting 300+ to the ground. Anyone have any thoughts on the subject?
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #2 of 13 (permalink) Old 07-31-2006, 05:45 PM
Worry about it when you break it nothing is "bulletproof"
post #3 of 13 (permalink) Old 08-01-2006, 04:17 PM Thread Starter
OAKEY DOKEY! I was just worring cuz I saw what happened to my buddies car when he broke his. (00-02 ? COBRA INSANE HP) He F-up a bunch of stuff. So I was just worried. What happens if they break on our cars?
2011 Kia Sorrento
1996 T-bird
post #4 of 13 (permalink) Old 08-01-2006, 09:10 PM
If they break you will be stuck where they broke at. With a traction lock and only one broken axle you can limp it off the road( or track) and change it there.
post #5 of 13 (permalink) Old 08-02-2006, 09:12 AM Thread Starter
How do you get the C-clip off the end of the halfshaft with out bunging the gears all up?
2011 Kia Sorrento
1996 T-bird
post #6 of 13 (permalink) Old 08-02-2006, 09:20 AM
It just slides out it's not a c-clip it's a circlip it will shrink because of the taper of the gears.
post #7 of 13 (permalink) Old 08-02-2006, 12:47 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Manual trans-totally different load and shock factor on the driveline.
JL
Fuelly
Johnny Langton is offline
post #8 of 13 (permalink) Old 08-02-2006, 02:31 PM Thread Starter
IT SLIDES OUT! You are Sh$#(NG ME! I have been pullin and pullin no luck.
2011 Kia Sorrento
1996 T-bird
post #9 of 13 (permalink) Old 08-02-2006, 02:54 PM
I put a prybar between the end of the axle and the differential and give it a good pop.
You cannot pull on the axle the cv joint will jsut pull apart.
post #10 of 13 (permalink) Old 08-02-2006, 02:58 PM
Originally Posted by dirtyd0g
I put a pry bar between the end of the axle and the differential and give it a good pop.
You cannot pull on the axle the cv joint will just pull apart.
Agreed! And sometimes it can be a pain to pull them out even with the crowbar. What I've found works well if they are "stuck" is to whack the main part of the half shaft with a hammer to give it a "shock" while prying with the crowbar.
"Main part" being the 5" diameter part that has the splined shaft that slides into the differential.
69 F100 LWB w/460 Engine
post #11 of 13 (permalink) Old 08-02-2006, 03:13 PM
btw, just to let you know, I personally think the SC shafts are a much better improvemnet over the LX shafts.....
I was at a junkyard the other day, and pulled the 3rd memeber out of an SC....holy shat, the SC shafts looked like they were more than twice the size of my LX shafts.
Also, the passenger side shaft was bigger than the drivers side.
Dirty Dog, can you run 2 passenger side SC shafts, say off a 90 SC, and put them on a 95 LX 4.6l?
post #12 of 13 (permalink) Old 08-02-2006, 03:15 PM
The driver and passenger shafts are the same lengths you can do whatever you want. I don't really see improvement because the shafts break on the outboard spline, but if it makes you more comfortable so be it. The markVIII ones are supposed to be hardened better that is what I am using. They also have a slightly larger shaft than stock lx ones.
post #13 of 13 (permalink) Old 08-02-2006, 03:17 PM
ahhh, gotcha.
thanks
edit: thats a trip....we have the same post count..and the same join date...weird
