Ebay Gears And Rebuild Kit - TCCoA Forums
post #1 of 8 (permalink) Old 08-04-2006, 02:34 PM Thread Starter
Is this kit very good quality? I'm looking to do 4.10 gears and I saw that this has everything you need to install it. But its not a name brand. I didn't want anything failing on me if I got it. And will 31 spline gears work?
http://cgi.ebay.com/ebaymotors/4-10-...QQcmdZViewItem
thanks
1995 Thunderbird
76MM MAFS, civic intake tube, K&N cone filter, mufflers removed
molisher is offline
post #2 of 8 (permalink) Old 08-04-2006, 02:42 PM
if its for the thunderbird they will not work i do believe its a 28 spline rear in your car ...also the axle bearings wont work either as they are not for a irs rear..
C F I FLY is offline
post #3 of 8 (permalink) Old 08-04-2006, 02:49 PM
Motive gears are decent gears but you'll need to be able to calculate pinion depth from their measurement. As he stated the 31 spline will not work and the axle seals and bearings will not work either.
post #4 of 8 (permalink) Old 08-04-2006, 02:51 PM Thread Starter
Does anyone sell a kit like this that will work in our cars?
1995 Thunderbird
molisher is offline
post #5 of 8 (permalink) Old 08-04-2006, 03:18 PM
Supercoupeperformance does I have gotten a couple from him.
Or you can compile the parts yourself through summit.
post #6 of 8 (permalink) Old 08-11-2006, 04:40 PM
justin case's Avatar
i didnt want to start another thread so ill piggyback a little (not trying to hijack ) but my car has a bad clunk when driving only when in gear and when i do a burn out it'll only leave one mark now where as it used to be both as it should is the kit for the re-build from scp a good choice or would it be cheaper from summit? thanks
justin case is offline
post #7 of 8 (permalink) Old 08-11-2006, 05:02 PM
The question is did your car come equppied with a traction lock differential? Bill's deal is fair I'm not sure what summit charges ,but if you don't have a traction lock you will need one of those as well. You'll also need to have the diff built it is not a job I suggest for those who are not experienced with it.
post #8 of 8 (permalink) Old 08-11-2006, 05:11 PM
i have a 3.27 trak lok,and yeah i was thinking about getting the kit but doubt i could handle it myself considering all ive ever done was set up a ford 9 inch rear at school almost a year ago
