Help me upgrade my trans cooler! - TCCoA Forums
post #1 of 16 (permalink) Old 08-07-2006, 06:54 PM Thread Starter
3rd Gear Chirper
hotbird's Avatar
I'd like to get one with a fan, and also with -AN fittings to use with braided stainless line instead of the rubber lines. What's everyone's opinion in regards to minimum fan CFM and GVW ratings of the cooler itself? Intended location is installed in front of the radiator, I have no condenser installed so there's plenty of space for anything.
The reason I'm upgrading is due to the fact that I'm considering a custom converter and as it is now the stock-spec Mustang converter pushes the temps over 180 when it's hot out and the car is driven hard. I forget what the specs on the existing cooler are though, so please don't ask I just got the largest plate cooler Discount Auto had at the time.
hotbird is offline
post #2 of 16 (permalink) Old 08-07-2006, 06:58 PM
Whining Intakes Rock
Al_Florida's Avatar
This is what I'm running:
Temps have stayed at about 180 (before I installed the blower).
Almost sure it was this one: http://store.summitracing.com/partde...5&autoview=sku
I don't remember exactly which one I bought but I don't see how I could have fit the larger one where I did.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 16 (permalink) Old 08-07-2006, 07:04 PM
Al_Florida's Avatar
So you're running no a/c then?
# 0 rows returned
post #4 of 16 (permalink) Old 08-07-2006, 08:50 PM
VicRattlehead's Avatar
this one
http://www.bulkpart.com/Merchant2/me...roduct_Count=3
or this one.
http://www.bulkpart.com/Merchant2/me...roduct_Count=4
CMP Drag Racing
VicRattlehead is offline
post #5 of 16 (permalink) Old 08-09-2006, 12:49 AM
Icarus's Avatar
The 4739 that Vic posted is a great cooler, I bought one a few months ago and they are very well built pieces
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
post #6 of 16 (permalink) Old 08-09-2006, 12:52 AM
+No need for a fan, just put it where it gets some air. No need for the external bypass either they are worthless. Run 3/8 steel lines directly to that massive cooler and your transmission will never over heat.
post #7 of 16 (permalink) Old 08-09-2006, 11:48 AM Thread Starter
3rd Gear Chirper
hotbird's Avatar
Yeah the car has no ac installed. May add it back later when all the mods are done, but probably not. It just gets in the way when working under the hood, there's alot more room w/o it.
Al, did it start getting hot when you added the blower, if so it may be the low cfm that fan puts out. It looks like a nice cooler otherwise.
dirtyd0g, what size is the stock line?
hotbird is offline
post #8 of 16 (permalink) Old 08-09-2006, 11:54 AM
Darrin's Avatar
With the coolers Vic posted, I can't find a way to run -an stuff to get to braided lines without some hodgepodge of fittings that will rob flow or using a compression fitting to go to 3/8 steel lines on each end.
If you find the parts to do it let me know
Darrin
Darrin is offline
post #9 of 16 (permalink) Old 08-09-2006, 02:15 PM
Al_Florida's Avatar
I haven't run it long enough to get it that hot since putting the blower on. With prices of 93 gas I've been trashing the wife's car instead. I've bypassed my radiator and it seems like the trans takes longer to heat up.
# 0 rows returned
post #10 of 16 (permalink) Old 08-09-2006, 07:42 PM Thread Starter
3rd Gear Chirper
hotbird's Avatar
Haha, yeah 93 gas=ripoff. And I guess the only way to get a good cooler with -an fittings is from Summit and the like.
hotbird is offline
post #11 of 16 (permalink) Old 08-10-2006, 12:59 AM
Icarus's Avatar
Why are the bypasses worthless? Do you think it's worthwhile to put bigger lines in? These questions will help both hotbird and I hopefully
Icarus is offline
post #12 of 16 (permalink) Old 08-10-2006, 01:13 AM
We tested the bypasses they only work at temperatures below freezing. At that point you are going to want to warm the car up before driving anyway. 3/8 lines are larger and yes I think they are worth using.
post #13 of 16 (permalink) Old 08-10-2006, 01:39 AM
Icarus's Avatar
Thxs
So being up here in Canada I should use the bypass?
Icarus is offline
post #14 of 16 (permalink) Old 08-10-2006, 06:23 AM
Dusty's Avatar
Originally Posted by Icarus
Thxs
Are you still using the cooler/heater in the radiator? Or stand alone cooler? No need for a bypass if you keep the heater in the system.
I run mine stand alone since my Cobra radiator has no cooler/heater. If you run stand alone in the winter in Canada you will have a tough time getting it warm enough. I have the bypass (Alan installed the cooler and bypass). I think we figured it opened below 70 degrees F, so it might help a little below freezing. I keep my car in the garage and let it warm up before driving in the N. Alabama winter. By the time I drive 15 miles to work it gets up to about 145 degrees F. What is too cool for transmission fluid? That is another discussion.
I plan on blocking the airflow on the cooler this winter and see what happens on my daily commute.
http://www.dana.com/Automotive_Syste...04_Website.pdf
Dusty is offline
post #15 of 16 (permalink) Old 08-10-2006, 09:59 AM
As far as I am concerned anything above 100 degrees is fine for transmission fluid temps. I really expected better control from the bypass. In canada I would have to think about hooking up the radiator for warming of the fluid. Blocking airflow in the winter is a great idea as long as you have a temp gauge to read it.
post #16 of 16 (permalink) Old 08-10-2006, 11:35 PM
Icarus's Avatar
So I'm probably fine with or without the bypass as long as I keep the OEM cooler in the rad hooked up as well...
Icarus is offline
