extreme drivetrain vibration question - TCCoA Forums
post #1 of 5 (permalink) Old 08-07-2006, 11:05 PM Thread Starter
just as the title says... very weird and loud vibration. I can feel it everywhere in the car between 40-80mph, but only when i let off the gas. During acceleration it is smooth.
whatever is shaking its coming from the rear, and i feel it in the seat, the wheel, the dash vibrates along with the shifter handle. Any and all ideas appreceated/willing to try.
ChitownLX is offline
post #2 of 5 (permalink) Old 08-07-2006, 11:54 PM
What's the condition of your motor/trans mounts? I know that a broken trans mount can cause lots of vibration at cruising speeds. Could also be your U-joints and even the differential mounts, but I'd start by checking the trans mount.
post #3 of 5 (permalink) Old 08-08-2006, 10:34 AM
bad93bird's Avatar
What about the tires? I've had many tires that had tread separation and caused this. Then again it could be the bushings and drive shaft u-joints. Maybe a tire is out of balance too. So much to check and so little time. You could have a bad shock too.
QUADSQUAD MEMBER
bad93bird is offline
post #4 of 5 (permalink) Old 08-08-2006, 03:20 PM
Whoa didn't even think of the tires!! And I should have known because I've had the tires be the cause of bad vibrations at certain speeds!!
post #5 of 5 (permalink) Old 08-09-2006, 09:46 AM
bad93bird's Avatar
Well????.....
QUADSQUAD MEMBER
