Difference between AOD and C4 - TCCoA Forums
post #1 of 3 (permalink) Old 08-09-2006, 02:17 PM Thread Starter
hey, my trans is about to shat, and i know i can get a C4 for it cheap, will it bolt in? i was told its the same lentgh, is that true? this will be goin into an 1986 tbird with the 5.0. any help is appreciated.
86Fordtbird5.0 is offline
post #2 of 3 (permalink) Old 08-09-2006, 02:51 PM
it should bolt in just fine....the length, I have no idea, it would be best to measure the 2 before starting the swap.
Also, make sure the slip yoke is/has the same number of splines.
Oh, the AOD TV cable will not be the same as a kickdown rod on the C4.....if you run the C4, you don't necessarily have to have the kickdown rod...unless you want to have it for passing gear(which you can still drop a gear manually, but since the tranny wasn't designed to always be manually shifted, this could cause problems later).
and the C4 doesn't have OD.(I'm sure you knew that one).
post #3 of 3 (permalink) Old 08-10-2006, 11:11 AM
Stick with the AOD
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
