Trans vibration shifting into OD 94 4.6 - TCCoA Forums
post #1 of 6 (permalink) Old 08-14-2006, 03:26 PM Thread Starter
HI, Just rebuilt my car after my sister wrecked it three years ago. Now sometimes I get a bad vibration for a second or so when it shifts into Overdrive. Is the fluid bad from sitting for so long or is the trans going out.
94 4.6l 124,000miles
thanks
jrlowscot is offline
post #2 of 6 (permalink) Old 08-14-2006, 06:05 PM
might be TC shudder. I would drain the TC and pan of fluid, change the filter and refill w/ Mercon V and see if that doesn't take care of it.
Does the vibration feel like you are running over the rumble strips on the highway shoulder?
Jay
FordMan77 is offline
post #3 of 6 (permalink) Old 08-14-2006, 07:36 PM Thread Starter
It feels exactly like driving on a rumble strip. Is that a sign of imminent failure? I was planning on taking a road trip soon
post #4 of 6 (permalink) Old 08-14-2006, 07:44 PM
Try changing the fluid to merconV. If the converter is still good that should save it for a while.
post #5 of 6 (permalink) Old 08-14-2006, 09:06 PM
SplitPortBird's Avatar
Agreed,, had a 93 lincoln do the same thing at 105K miles.. drain the TQ converter and changed the filter and refilled with mercon V plus I added a bottle or DR. Tranny shudder fix and its been smooth as silk for about a year now.
SplitPortBird is offline
post #6 of 6 (permalink) Old 08-15-2006, 08:33 AM
You may also want to add a 24K or larger trans. cooler. Couldn't hurt.
Jay
