Mlps/trs - TCCoA Forums
post #1 of 7 (permalink) Old 08-20-2006, 10:04 PM Thread Starter
Mlps/trs
where on the transmission, is the MLPS sensor located,and is the mlps the same as the trs sensor,if not where are they both located.
ThunderBird 94 is offline
post #2 of 7 (permalink) Old 08-20-2006, 10:14 PM
The MLPS is the large black sensor on the driverside of the transmission where the shift cable attaches.
-Rod
post #3 of 7 (permalink) Old 08-20-2006, 10:39 PM Thread Starter
what is the proper way to change it?
post #4 of 7 (permalink) Old 08-21-2006, 01:33 AM
I used an 8mm socket/ wrench. It's a tight space since the exhaust pipe is in your way (at least on a Mark VIII). Jack it up, park it in neutral, set the e-brake, disconnect the sensor harness, two bolts out with an 8mm socket/wrench, match the "neutral position" on the new sensor (you'll know what I'm talking about when you see it), reverse installation. Easier said than done, but overall, a 30-45 minute job.
Two things: do it on a cool car. The exhaust pipe is right there!
Second: buy the part from Autozone- it's only $22. I think NAPA wanted more, and forget about what Ford charges for it!. Just ask for a "neutral safety switch". They're typically in stock. Changing this sensor helped fix a shifting probelm I was having at cruising/ highway speeds...
See the biggest of the holes in the center of the sensor? That's the "neutral position" I was talking about. Make sure the position of the notches on the new sensor matches the old one. This tells the computer that the transmission is in neutral.
evillally is offline
post #5 of 7 (permalink) Old 08-21-2006, 08:36 AM Thread Starter
should I disconnect the battery cables, or dosen't it matter?
post #6 of 7 (permalink) Old 08-21-2006, 12:15 PM
I would anyway.
post #7 of 7 (permalink) Old 08-26-2006, 09:54 PM Thread Starter
well I replaced the MLPS aka neutral swith, drove the car 50 miles,this is the first time in 3 years the trans didn't go out of gear,thank you all for your help, I have a normal trans now.
