2 JMOD questions - TCCoA Forums
post #1 of 14 (permalink) Old 08-21-2006, 01:27 PM Thread Starter
JNT
JNT's Avatar
2 JMOD questions
Worked on the J-Mod yesterday and hope to finish tonight. Actually insalling an already modified valve body.
Couple questions:
There is a plastic piece (cable tie) holding the cables in place that connected to the VB. I broke the part that goes into the VB. Will there be an issue with the wires hanging freely?
Step 15 of the article mentions a filter near the rear of the VB.
"There is also a little black cone-shaped filter that goes into the transmission case near the rear of the transmission (towards the driveshaft). Be sure that it hasn't fallen out as well. DO NOT LEAVE IT OUT."
I had a very small black plastic piece starting to fall out but it didn't look like a filter. Does anyone have a picture of this?
1997 Thunderbird 4.6L LX (out of commission for now)
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1996 Thunderbird 4.6L LX Stock
1994 Thunderbird SC (Needs Work, for sale)
1996 Bronco XL - 2003 Escort ZX2 wrecked - 1996 Bronco XLT Sport
Project Car: 69 Lincoln Continental
JNT is offline
post #2 of 14 (permalink) Old 08-21-2006, 02:47 PM
wether's Avatar
I can post a picture of one when I get home work as I have one apart now. . . . .Here is a Paint image of what it should look like. The white "triangle" area is a white screen filter:
http://www.guardcows.com/4R70W_Cone.GIF . It will take some time to load the image as my server connection is slower than I would like. I will leave the link active for your future viewing!
Hope this helps!
Kenneth
wether is offline
post #3 of 14 (permalink) Old 08-21-2006, 03:00 PM Thread Starter
JNT
JNT's Avatar
Thanks for the picture. Is it really small, black plastic about 1" in length ?
JNT is offline
post #4 of 14 (permalink) Old 08-21-2006, 03:01 PM
holy save it as a GIF so it is 2k instead of 700k bitmap!
Bangster is offline
post #5 of 14 (permalink) Old 08-21-2006, 03:08 PM
wether's Avatar
yeah, 1" +/- 0.25". I just remember it isn't much longer than my thumb nail. . . .I really know that this reference doesn't help you! LOL
wether is offline
post #6 of 14 (permalink) Old 08-21-2006, 03:13 PM
wether's Avatar
Done!
Post edited to reflect change. . . .
wether is offline
post #7 of 14 (permalink) Old 08-21-2006, 03:18 PM
I didn't mean to sound rude, you took the time to do it and it will likely help out, but it loads a thousand times faster as a GIF.
I don't remember seeing that when I j-modded my tranny, but I must not have knocked it out or dealt with it. I also don't remember the wiring, I know mine seemed like it was going to be brittle the next time I did anything there, I like the printed flex ribbon cable in my 00 Grand Marquis.
Bangster is offline
post #8 of 14 (permalink) Old 08-21-2006, 03:35 PM
wether's Avatar
I didn't think you were being rude. . . .no offense taken. I should have noticed that when I was uploading it to the server and even saving it from Paint, but my mind is in several places today. Thanks for helping me fix that little lack of consciousnous.
This filter is located in the worm tracks near the backside (output shaft) of the transmission. Near the center (taken Right to Left) of the transmission there are two little openings. This filter sits in the one on the side where the 1-2 accumulator is located. This hole goes all the way through to the extension housing and I have had to take it out sometimes by using a long Q-tip to push it out from the extension housing side before cleaning of the case.
Hope this helps locating it. . . .
Kenneth
wether is offline
post #9 of 14 (permalink) Old 08-21-2006, 05:09 PM Thread Starter
JNT
JNT's Avatar
Kenneth
Do you mean the 2-3 accumulator? The 1-2 is at the front the 2-3 is at the back closer to the drive shaft.
JNT is offline
post #10 of 14 (permalink) Old 08-21-2006, 09:52 PM
wether's Avatar
Left to right it is on the side with the 1-2 accumulator. . . .front to back it is in the back of the tranny. . . . .I will go take a picture right now. Give me a few minutes to upload.
wether is offline
post #11 of 14 (permalink) Old 08-21-2006, 10:22 PM
wether's Avatar
http://www.guardcows.com/4R70W_Cone1.jpg
http://www.guardcows.com/4R70W_Cone2.jpg
The red circles are where the filter in question should be. . . .and here is the filter:
http://www.guardcows.com/4R70W_Filter.jpg
I included a penny as a frame of reference for the size. . . .
Let me know if I can do anymore!
Kenneth
wether is offline
post #12 of 14 (permalink) Old 08-21-2006, 11:08 PM Thread Starter
JNT
JNT's Avatar
Cool wether, thanks for the pictures. Yeah thats the piece I saw. Anyone know what this does exactly? Really small for a filter.
Decided to take the night off and finish it up tomorrow.
JNT is offline
post #13 of 14 (permalink) Old 08-21-2006, 11:23 PM
wether's Avatar
Since the bore goes down to lubricate the output shaft journal, I would guess that it is there to catch any metal pieces that may come off of the bearing/bushing at the other end. These could cause problems with the fluid flow to/from the valvle body if contaminated. . . . .just my take on the question.
wether is offline
post #14 of 14 (permalink) Old 08-22-2006, 02:04 PM Thread Starter
JNT
JNT's Avatar
Makes since.
JNT is offline
