Installing trans temp sender - TCCoA Forums
post #1 of 6 (permalink) Old 08-25-2006, 10:17 PM Thread Starter
miller1995's Avatar
Tranny gurus, I need to install a trans temp sender for my gauges, I am debating between two methods in the pan or in line. If i was to put in the pan, which is what I am leaning towards right now, I woul ddrill and tap a hole in an aftermarket pan. Haven't quite figured out a way I really like of mounting the sinder in line. If I was to go the pan route, which pan would you recomend? Or, if you prefer the in line method what would be the best way?
-Bryan Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #2 of 6 (permalink) Old 08-27-2006, 01:34 PM
I chose to mount mine in the transmission pan. I bought a B&M drainplug kit, installed it on the stock trans pan, and installed the sending unit in place of the drain plug (same threads).
-Rod
post #3 of 6 (permalink) Old 08-27-2006, 03:41 PM
Traveler's Avatar
Hey I like that idea. My pan already has a drain plug in it.
Thanks again Rod!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 6 (permalink) Old 08-27-2006, 06:48 PM
You might want to read this...it sheds some light on the subject.
http://forums.tccoa.com/showthread.php?t=88213
96SOHC is offline
post #5 of 6 (permalink) Old 08-27-2006, 10:32 PM Thread Starter
miller1995's Avatar
Already did, I think I may go for an aftermarket pan but wanted to get some opinions on mounting locations and pan selection from some of the trans guys.
-Miller
SOLD1998 Escort ZX2
post #6 of 6 (permalink) Old 08-28-2006, 12:26 AM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
Personally, I would put the sensor on the fluid line to the rad. This will give you the hottest temp of the fluid and that is more important IMO than knowing the temp in the pan. The hotter the trans fluid gets, the more it breaks down so knowing it's hottest point is likely what you are after, or if it was my car, what I would want to know.
TGJ is offline
