OEM Explorer Gears? - TCCoA Forums
post #1 of 5 (permalink) Old 09-04-2006, 10:13 PM Thread Starter
OEM Explorer Gears?
Would OEM Explorer 3.73 gears work in my car? And what else would I need? Also, why exactly do I need to get a chip for them? i have 3.08s right now
I was looking at these:
http://cgi.ebay.com/ebaymotors/79-04...QQcmdZViewItem
thanks
1995 Thunderbird
76MM MAFS, civic intake tube, K&N cone filter, mufflers removed
molisher is offline
post #2 of 5 (permalink) Old 09-04-2006, 10:14 PM
The Great Obucina's Avatar
8.8 gears are 8.8 gears period.
although, you need a 28spline diff and FYI explorer rear ends - the IRS ones are notorious for making noises diffs arent supposed to make.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 5 (permalink) Old 09-05-2006, 12:09 AM
I would look the gears over good before buying them. It wasn't so much of a gear problem but initial installation being off. And if you buy gears that were installed improperly and broken in that way when you set them up right they will whine. Most of the explorer diff problems was chatter in corners from the clutches.
post #4 of 5 (permalink) Old 09-05-2006, 07:45 PM Thread Starter
So would the ebay ones be worth buying? and i need a chip reburn too, right?
1995 Thunderbird
molisher is offline
post #5 of 5 (permalink) Old 09-05-2006, 07:49 PM
If you can look them over they are worth buying. It comes down to inspection.
