Tranny fluid in coolant Help ASAP - TCCoA Forums
post #1 of 6 (permalink) Old 09-15-2006, 07:08 PM Thread Starter
hey you guys I have had this prob i barely noticed it there was tranny fluid in my coolant reservoir. I have a bad feeling this is fgoing to cost alot I have atranny coolr I am guessing my tranny cooler can get flushed then putsome new tranny fluid but do I have to flush the tranny and the coolant since they are probably both mixed. I need help will I need a new tranny or sometihng how do you know if you do please help me I need help. If someone can tell me a good radiator (performance) wise that will be better than the 97 one. thanks
veyito_169 is offline
post #2 of 6 (permalink) Old 09-15-2006, 07:20 PM
I believe Griffin is making radiators for our cars now. I'd ask Lonnie I think he got a deal with them. I hope you aren't getting water int he transmission as well because it will cause the clutches to all peel off.
post #3 of 6 (permalink) Old 09-15-2006, 08:00 PM Thread Starter
how do you know if you do Alan I need to check im going to flush both systems.
post #4 of 6 (permalink) Old 09-15-2006, 08:16 PM
If the trans fluid looks pink drain it and change it immediately, drive it a little to warm it up and do it again. I would just use dexIII as a "flush"
post #5 of 6 (permalink) Old 09-16-2006, 01:23 AM Thread Starter
oh ok Thanks
post #6 of 6 (permalink) Old 09-17-2006, 11:05 PM
I recently had the same thing. I caught it early (car was in the shop getting an AC hose/muffler assembly replaced and the system recharged) but I had a SLIGHT indication of water in the tranny fluid, mainly I had serious strawberry shake thing going in the coolant.
I drained and replaced the Mercon V in the tranny, it did not look at all like water and oil mixing, not in the external cooler, the radiator cooler, the tranny, or the torque convertor. I would guess in my situation the tranny line pressure was far higher than the cooling system.
I am still to this day trying to get the cooling system cleaned out. I get a tiny bit of tranny fluid that sticks to the edges of the degas bottle, I stick a paper towel in there and soak it up. I think I am done now, it has been 500 miles since the last time I cleaned it, and there is nothing floating.
Bangster is offline
