Car will not start in neutral - TCCoA Forums
post #1 of 3 (permalink) Old 09-18-2006, 01:18 AM Thread Starter
Just had a new engine put in with a Hitachi Starter. Now the car will not start in neutral at all...Car will only start in Park. Could anyone advise what may be causing this problem?
AED 9 PSI Supercharger, .30 over Forged Block with Manley H-Beam Rods & Pistons, Innovative West 10% Overdrive Crank Pulley, Thump RRR Tensioner Pulley, Cobra Crankshaft, BPE Racing Stage 2 Ported & Polished Heads, Crower Direct Replacement Cams, 70MM Throttle Body, MAC Cold Air Intake, 80 MM L-MAF, 38Lbs Injectors, JBA Ceramic Coated Headers, Metal Matrix Drive Shaft, Kevlar Clutch & Kolene Reaction Plate Transmission, True 2.5" Dual Magnaflow Exhaust (Cats & Mufflers), Griffin 1 1/4" Radiator, B&M Racing Trans Cooler, Hughes 2750 Stall Torque Converter, 3.73:1 Gears with Traction Lock Differential, Trans-Go Kit, Superchips Custom Tune for Supercharger, 17" SVT Wheels, Kenny Brown Suspension Enhancers & Eibrach Lowering Kit.
Wolverine27 is offline
post #2 of 3 (permalink) Old 09-18-2006, 04:21 AM
ZackG's Avatar
i didnt know you could start it in neutral..
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #3 of 3 (permalink) Old 09-18-2006, 06:19 AM
mlps bad or out of adjustment. That could fry the transmission if you don't fix it.
