Mobil 1 Synthetic ATF Mercon v - TCCoA Forums
post #1 of 11 (permalink) Old 09-23-2006, 04:14 PM Thread Starter
Faster than Porkchop
cjchevez's Avatar
Hey guys need your help .
I looked for Mercon V today at Autozone ,Wal Mart , and Pepboys .
None had a a good selecion of ATF .
They only had Mobil 1 Synthetic multi-vehicle formula at 7.99 a qrt .
Is it ok to go with Mobil 1 ? It says Dexron/Mercon and Mercon v and approved for
H specification .
Also how many qrts do I need ?
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #2 of 11 (permalink) Old 09-23-2006, 05:13 PM
JustinH's Avatar
as far as I know, the Mobil1 does not meet Mercon V spec.
Autozone and pep boys both have Mercon V, it will say Mercon V on the front of the bottle.
It should be about 3 bucks a quart.
Need 12-13.
JustinH is offline
post #3 of 11 (permalink) Old 09-23-2006, 09:50 PM
Icarus's Avatar
I'm pretty sure the new formulations of Mobil do meet the specs, but you will need to look at the bottle to be sure... I ran into this same situation when I went to put Mobil 1 I have sitting in my garage into my car. I emailed Mobil 1 and they said look at the bottle... So check the bottle to see if it's old stock or new...
  • Dexron III, Dexron IIIE, Dexron
  • Approved for H specification, the latest GM Dexron III performance level
  • Mercon, Mercon V
  • Recommended for Allison C-4 and Caterpillar TO-2 applications
  • Recommended for Chrysler automatic transmissions
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
post #4 of 11 (permalink) Old 09-23-2006, 10:32 PM Thread Starter
cjchevez's Avatar
So is it better to just go with Meron v as apposed to the multi-vehicle formula ?
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #5 of 11 (permalink) Old 09-24-2006, 12:20 AM
You can use Mobil I synthetic ATF. I have been using it for years. It will probably stand up better than the Motorcraft stuff.
Mitch
MitchB is offline
post #6 of 11 (permalink) Old 09-24-2006, 08:30 AM
Carlover007's Avatar
I'm using that with my 3200 stall tq and I think it works great, no problems so far.
Carlover007 is offline
post #7 of 11 (permalink) Old 09-24-2006, 09:24 AM
JustinH's Avatar
i'd use the regular stuff, because you need to change it once a year anyways.
JustinH is offline
post #8 of 11 (permalink) Old 09-24-2006, 04:30 PM
Once a year? Do you change filter at the same time as well?
post #9 of 11 (permalink) Old 09-24-2006, 04:47 PM
I have to go to 2 or 3 places to get 12-13 quarts of Mercon V of matching manufacturer for each of my 4r70w cars. I like to be able to find 13 quarts of Castrol, but the last two times I have had to use AAMCO. I don't remember who makes it, I think Exxon.
I change mine once a year, every 20k miles, in the Grand Marquis, along with the filter.
I don't put many miles on the 97, only around 11k a year, so every other year for it. The 89 gets Mercon whenever something happens that requires a fluid change, usually the two small sections of soft tranny line near the radiator bursting or rotting from the heat. I can't find the Motorcraft memo on stopping from licensing Mercon to aftermarket, I assume the 89 will be off the road before that happens, or I will go to a universal oil. I still don't know what that means for the 4R100 crowd.
That would get expensive, 8 bucks a quart at 13 quarts, but a new tranny is a little bit more, and a lot of work. I am debating on if I want to go with it next fluid change for the 97 Cougar, 110 bucks in fluid over three years isn't a big deal, 110 bucks a year is.
But I go the other way in the engine oil department since it isn't a big price difference, the 00 Grand Marquis (I bring it up because it has the same basic engine/tranny combo, nearly the same weight, etc) gets the extended oil (15k miles) so I have one oil change a year (and one add up quart of oil), but the Cougar gets the regular 5k stuff, or Motorcraft semi synth when I can get it for 2.25 a quart (at Wal-Mart very infrequently for 5w30, usually only have 5w20).
Bangster is offline
post #10 of 11 (permalink) Old 09-25-2006, 06:41 PM Thread Starter
cjchevez's Avatar
http://cgi.ebay.com/ebaymotors/Motor...em190033076936
For someone in Va , this might be a really good deal on Mercon V .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #11 of 11 (permalink) Old 09-25-2006, 08:18 PM Thread Starter
cjchevez's Avatar
No one needs a case of Motorcraft MerconV ( bid is at 14.99)?
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
