Still have driveline vibration problems - TCCoA Forums
post #1 of 9 (permalink) Old 10-03-2006, 03:17 PM Thread Starter
KevinM's Avatar
Send a message via AIM to KevinM
I have been fighting a driveline vibration ever since I installed a new pumpkin that I bought off Ebay with 3.73 trac loc in it. It is a cast itron pumpkin. I had new u-joints put on the OEM driveshaft and then had it straightened and balance. THat mad eit worse. THen I had the same shop make a new one piece steel shaft with the original ends and it was better, but still gave vibration at highway speeds, finally I broke down and bought a 1 piece aluminum Mark VIII shaft and put the new u-joints on it from the other shaft and I still have a vibration at highway speeds. It is definately better, but still gets real bad at 80+. I am scared to take the car to the dragstrip because I don't want to know what might happen at 100+ mph. I am speculating that because I put new u-joints on the aluminum shaft, that I may just need to get it balanced, but I do not want to go to the same place that already did my stock one becasue they didn't seem to help. So does anyone know of a good place between Atlanta, GA and Charlotte, NC to take a shaft to be balanced. THe other question is, is there a possibilty that it is somehitng like a halfshaft issue, or an imbalance related to my rear drum brakes. I have not rotated the tires yet to eliminate that, but it just gets constantly worse at highway speeds. Could be something about the pinion angle of the pumpkin, or something internal to the gears? Any recommendations would be greatly apprecaited.
Kevin M
KevinM is offline
post #2 of 9 (permalink) Old 10-03-2006, 03:38 PM
wether's Avatar
transmission mount or tire sounds most likely since it sounds like you have exhausted the driveshaft as a possibility. . . . .just what I would try next.
wether is offline
post #3 of 9 (permalink) Old 10-03-2006, 04:12 PM
post #4 of 9 (permalink) Old 10-03-2006, 05:29 PM
FordFanatic's Avatar
have you tried moving the driveshaft into a different bolt pattern?
FordFanatic is offline
post #5 of 9 (permalink) Old 10-03-2006, 08:50 PM Thread Starter
KevinM's Avatar
Yes I have tried all the bolt patterns that I can and the one I have it in now seems the best. That is one thing that still leans me toward the blanace of the shaft. Is it always necessary to balance a shaft after installing new u-joints?
Kevin M
KevinM is offline
post #6 of 9 (permalink) Old 10-04-2006, 10:52 AM
wether's Avatar
I have never had to balance a shaft after changing u-joints. . .
wether is offline
post #7 of 9 (permalink) Old 10-04-2006, 12:31 PM
Try this...
Loosen the bolts on the tranny mount just enough to free it up then take the car out for a spin. When you get back, tighten the mount back up. This will let the tranny and driveshaft "find center alignment" with each other.
LJGriggs is offline
post #8 of 9 (permalink) Old 10-04-2006, 12:33 PM Thread Starter
KevinM's Avatar
What speed should I go to with the tranny mount loose? The vibration usually does not occur until somewhere near 80 mph.
KevinM is offline
post #9 of 9 (permalink) Old 10-04-2006, 12:38 PM
I don't know if I would recommend doing 80mph with the mount loose, but just a short cruise getting up to 45mph should do the trick. You basically just want to let the spinning shaft find its "center".
LJGriggs is offline
