governor - TCCoA Forums
post #1 of 14 (permalink) Old 10-12-2006, 09:31 PM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
governor
how do u take the governor out, besides chip right know dont have enough money for it right have to buy a winter vehicle
94fastbird is offline
post #2 of 14 (permalink) Old 10-12-2006, 09:34 PM
chip or tune is all I know of....
post #3 of 14 (permalink) Old 10-12-2006, 10:58 PM
SR-71Blackbird's Avatar
it's electronically governed, u can't physically 'take it out'
1997 4.6L LX SPORT, rollin on 19's
http://www.cardomain.com/ride/856858
http://s12.photobucket.com/albums/a241/steviewonder13/
PI heads, PI intake, Comp 262's, Comp Valve Springs, Kooks headers, 3.73 TL, 180*T-stat, RSTB, lowered 1.5", A/C Delete Pulley, Custom exhaust. Block #2
-- SCT dyno tune 279RWHP & 310RWTQ - DD tune, SAE corrected
14.5 @ 97mph (need a higher stall, car bogged w/ stock converter + mickeys, lol)
SR-71Blackbird is offline
post #4 of 14 (permalink) Old 10-12-2006, 11:24 PM
Yes the computer limits the speed of the car, but it's there for a reason. Driveline critical speed...
post #5 of 14 (permalink) Old 10-13-2006, 04:52 PM
One thing to try nobody knows what will happen is to find the resistance of your speed sensor and wire a cut off switch into it set at just before the limiter that will trick your car into think its going 110 or so but you will actually be going faster. All that I would think happen is the comp would think that your trans is slipping and take appropriate actions given that situation. No guarentees but if this works it would be cool.
Do this at your own risk and please don't flame me for it. this would be the only way to fix the limiter other than a chip.
1996 sport 4.6 130k and still strong.
1991 SC 3.8 project and toy.
ncoop23 is offline
post #6 of 14 (permalink) Old 10-13-2006, 05:35 PM
That might work. I would say if your driveline has been upgraded from stock, then go for it. If not, then it's just a matter of time before something will give out, be it the TC, the driveshaft or whatever. Never tested the limits of a stock drivetrain myself.
Jay
FordMan77 is offline
post #7 of 14 (permalink) Old 10-13-2006, 06:35 PM
The Great Obucina's Avatar
i would definately not recommend doing that.
"Booyah". Stu Scott.
The Great Obucina is offline
post #8 of 14 (permalink) Old 10-14-2006, 07:11 AM
I used to have a slight vibration @ 100 mph after installing a balanced 1pc steel driveshaft with the 3.73 gears. Old diff bushings and broken rear diff mount in my car [all looked good when the diff was installed]. Now the vibration is scary over 100 mph. The rear seal is leaking on the trans from the wallowed bushing.
Just testing the new Mustang computer one day I got the car to 120 mph on an open road. Scared the crap out of me! The vibration was so bad I had to look at the u-joints to see if they were loose. Now I have a beefed up MarkVIII subframe and aluminum driveshaft to install.
So yeah, no point in bypassing the speed limiter until you brace the diff, get new poly diff bushings, and a new 1 pc aluminum driveshaft. By that time a chip is pocket change.
You might even drop to second gear with the 4r70-w when the switch is flipped
icantdrive55 is offline
post #9 of 14 (permalink) Old 10-14-2006, 09:57 PM
Back in Black
ShadowDragon's Avatar
Wouldn't that make your speedometer be way off?
ShadowDragon is offline
post #10 of 14 (permalink) Old 10-14-2006, 11:13 PM
Also ain't the Speedo/output shaft speed sensor a Hall effect (read: Pulse) kinda sensor?? So adding a resistor, ect will not do anything??
i had my '91 to 130mph... was good and smooth.. But perfer not to go there again.. the '96 I don't think i've hit 90MPH yet
91 XR7 is offline
post #11 of 14 (permalink) Old 10-14-2006, 11:22 PM
Back in Black
I really have no idea. in that case if you resistor it too low you might not get any usuable signal at all.
post #12 of 14 (permalink) Old 10-14-2006, 11:23 PM
I think the diff mount and bushings are the main factor in bad vibes. Mine was fine after shimming the factory bushings. They have been abused too much.
post #13 of 14 (permalink) Old 10-14-2006, 11:27 PM
Back in Black
Once you get used to the car you'll be able to determine what part is causing the vibe, I knew what speed my old tires were starting to protest, and at what speed the driveshaft started looping wider.
post #14 of 14 (permalink) Old 10-15-2006, 04:16 PM
Idk how the snesor works but it shouldn't be that hard to make a signal generator box if it is a hall efect sensor. And the stock speedo only goes to 120 anyway so if you flick the switch it will make your car think you are going 110 or whatever you have it set to but your rpms will be higher.
ncoop23 is offline
