gear question? - TCCoA Forums
post #1 of 2 (permalink) Old 10-17-2006, 11:24 AM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
gear question?
hey guys just wondering the difference in gains from a 3.08 gears - 3.73 gears? is there gonna be alot me spin off the line? see i want me get up and go so what are the the thing a should do for this? tranny? gears? and driveshaft upgrade?
94fastbird is offline
post #2 of 2 (permalink) Old 10-17-2006, 11:33 AM
Banned
you will notice more of a kick off the line. mine has wheel hop and gains traction in a second or too even with my rebuilt trac-lok. all you have to do is just ease on the pedal for the most effeciancy *sp*
if you do go to 3.73's yes i would upgrade the driveshaft while your at it. just look for a mark 8 in the local junkyard and pull out an alluminum one piece driveshaft out of it. make sure its out of a 93 and that its a one peice. then get that sucker high speed balanced. i had drivetrain vibration when i used my stock driveshaft swapping to 3.73's.
also if your car doesnt have trac-lok *fords limited slip* then i would wait to get a rear end that has trac-lok like off a mark 8 again seeing how they are all alluminum and weigh 20lbs lighter than our stock ones. make sure its limited slip.
and last but not least look into a j-mod *custom shift kit* and a tranny cooler. i did 3.73's/jmod/ecu tune and it was a DIFFERENT car lol
Porkchop is offline
