gearing - TCCoA Forums
post #1 of 5 (permalink) Old 10-29-2006, 06:15 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
gearing
well i was reading i have a question about my 5spd swap. well i read that the 5spds came with 2.73's right? well if i leave the stock gears there then i will have a 5 in front of 3.27's what kinda probs will i have there?
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #2 of 5 (permalink) Old 10-29-2006, 07:31 PM
It will be comparable gearing to running an automatic with 3.73s. You'll turn higher revs on the highway, and you'll have more off the line acceleration, and first gear will be very quick, but it won't cause any problems as long as you use the correct speedo gear.
Mike
post #3 of 5 (permalink) Old 10-29-2006, 07:50 PM
Baby Huey
warmaster259's Avatar
My dads GT came w/ a t-45 and 3.27's. Not a problem at all
Jim
warmaster259 is offline
post #4 of 5 (permalink) Old 10-29-2006, 07:56 PM
If you are running a T5, then there is no change in gearing from an automatic. My comment was for if you are using an M5R2, which is the trans that came in SCs which had 2.73s.
Mike
post #5 of 5 (permalink) Old 10-29-2006, 08:58 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Alright mike thanks. give me alittle more info and helps alot.
ZeroRain is offline
