Axle Leaking - TCCoA Forums
post #1 of 2 (permalink) Old 10-30-2006, 03:20 PM Thread Starter
Axle Leaking
Noticed my axle is leaking from the axle seal at the pumpkin.
Can anyone tell me the easiest way to replace this?
97TXBIRD is offline
post #2 of 2 (permalink) Old 11-01-2006, 06:56 PM
3rd Gear Chirper
hotbird's Avatar
Remove the axle, pull the seal out with a seal puller (or you might be able to pry it out with a flathead screwdriver). Then drive the new seal in with a socket, pipe, seal driver, whatever...just make sure it goes in squarely. Reinstall axle and you're done.
hotbird is offline
