Tail Casing HELP - TCCoA Forums
post #1 of 6 (permalink) Old 11-02-2006, 05:47 PM Thread Starter
The Stevinator's Avatar
Tail Casing HELP
does anyone know what
47
W
means on the tail case of a transmission?
The Stevinator is offline
post #2 of 6 (permalink) Old 11-09-2006, 10:02 PM
i know that the "W" means wide ratio, which is the gear ratio between the 1st to 2nd gear shift, the "4" means 4 speed, but im not sure what the "7" means yet
Gator1980 is offline
post #3 of 6 (permalink) Old 11-10-2006, 02:24 PM
4R70W is 4 speeds, rear wheel drive, 700 foot pounds of torque handling Wide ratio.
Does that have anything to do with
47
W
on the tailshaft? I don't know, I have never looked for markings or anything on one.
Bangster is offline
post #4 of 6 (permalink) Old 11-10-2006, 02:36 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Originally Posted by Bangster
4R70W is 4 speeds, rear wheel drive, 700 foot pounds of torque handling Wide ratio...
Can anyone verify that 70=700 ft/lbs? I have heard many times that the higher the number, the stronger the tranny but this is the first time I have seen that the number actually means a specific rating.
tinman_72 is offline
post #5 of 6 (permalink) Old 11-10-2006, 03:30 PM
I can't find my reference. I looked it up and didn't stop at "it is on the Internet, that means it is true", but I don't remember where I found it.
4R100 is 1000
5R55W is 550
That is input to transmission from TC, so that is closer to 500 ft pounds engine torque output for the 4R70W
Bangster is offline
post #6 of 6 (permalink) Old 11-10-2006, 03:46 PM
jhosler's Avatar
Send a message via AIM to jhosler Send a message via MSN to jhosler Send a message via Yahoo to jhosler
this is from the f150 forums http://www.f150online.com/forums/sho...threadid=61285
check out reply #7
-Jason
2001 Lincoln Continental Limited
2006 Suzuki Boulevard M50
jhosler is offline
