4r70 internal to AOD Q's - TCCoA Forums
post #1 of 1 (permalink) Old 11-10-2006, 04:03 PM Thread Starter
Old_coot's Avatar
Send a message via Yahoo to Old_coot
I have an AOD with several good parts that I want to upgrage. I have the mechanical diode and a donor 4r70.... I know I need the reverse drum and am also looking at swapping in the wide ratio. what all else is needed????
Also the AOD that I tore down had the needle/roller bearings in it. Will I be able to use these with the 4r70 swap????
Old_coot is offline
