Tbird and mustang 8.8 compatable? - TCCoA Forums
post #1 of 10 (permalink) Old 11-12-2006, 11:54 AM Thread Starter
95xbird's Avatar
I am curious to know if a 8.8 from a fox tbird whould cross over to a fox mustang???Are they they same?Is there any years that the housing was different??
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #2 of 10 (permalink) Old 11-12-2006, 12:32 PM
Maxion$Mulla$'s Avatar
I think the spline is different. dont know too much about it though. If im right its 31 spline and the tbird is 28 spline.
Kevin
94 t-bird parting out in the classifieds
Selling a Panasonic cd player 40x4 with 1 set of preouts
and a Yamaha warrior front fender- yellow Classified as SPEED DEMON! Mutha
Maxion$Mulla$ is offline
post #3 of 10 (permalink) Old 11-12-2006, 12:34 PM Thread Starter
95xbird's Avatar
Well no i dont think so.A guy a work with builds race fox bodys and he claims the stangs take the 28 spline axel.
Main thing he is looking to do is swap out a 7.5 for the 8.8 in his 86 stang.
But he cant seem to find one from a mustang so i recommended the t-bird as an option.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #4 of 10 (permalink) Old 11-12-2006, 01:08 PM
SR-71Blackbird's Avatar
marks VII's are 28
1997 4.6L LX SPORT, rollin on 19's
http://www.cardomain.com/ride/856858
http://s12.photobucket.com/albums/a241/steviewonder13/
PI heads, PI intake, Comp 262's, Comp Valve Springs, Kooks headers, 3.73 TL, 180*T-stat, RSTB, lowered 1.5", A/C Delete Pulley, Custom exhaust. Block #2
-- SCT dyno tune 279RWHP & 310RWTQ - DD tune, SAE corrected
14.5 @ 97mph (need a higher stall, car bogged w/ stock converter + mickeys, lol)
SR-71Blackbird is offline
post #5 of 10 (permalink) Old 11-12-2006, 01:27 PM Thread Starter
95xbird's Avatar
But can the housing from a Fox bird,cougar,or mark swap over to a fox stang?Axel splines arent an issue it is mainly the straight axel housing we are looking for.
Larry
Its slow, Really.
LS1 KILLER
95xbird is offline
post #6 of 10 (permalink) Old 11-12-2006, 10:18 PM Thread Starter
95xbird's Avatar
Does anyone know if they can be swapped???
Its slow, Really.
LS1 KILLER
95xbird is offline
post #7 of 10 (permalink) Old 11-13-2006, 12:24 AM
The housings are the same width, and the upper & lower control arlms bolt in the same. The Fox T-Bird has different quad shock backets, and the Lincoln MK VII doesn't have any. The Fox Mustang parts can be swapped over if you swap axles, drums and backing plates. The T-Bird axles are a little longer and use specific drums to match them.
Decy is offline
post #8 of 10 (permalink) Old 11-13-2006, 10:52 AM
JustinH's Avatar
In other words, you probably want to use an IRS rear.
99 cobra had 373 with the ford limited slip and aluminum housing
Mark8 had the aluminum housing.
Your run of the mill tbird has the iron housing.
JustinH is offline
post #9 of 10 (permalink) Old 11-13-2006, 03:34 PM Thread Starter
95xbird's Avatar
Thanks guys.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #10 of 10 (permalink) Old 11-13-2006, 03:36 PM
The Great Obucina's Avatar
fox birds and mk7s homie........
"Booyah". Stu Scott.
The Great Obucina is offline
