trans temp gauge hook-up - TCCoA Forums
post #1 of 11 (permalink) Old 11-13-2006, 09:20 PM Thread Starter
i wanna hook my trans temp gauge into my trans line but i dont know excatly how to get it in the line? my trans isnt stock and it runs about 70-80 psi of line pressure so im assuming that splicing the line and using rubber hoses is out of the question. its an electric gauge so it has the sender. i was thinking a "T" fitting but i dunno how to get it connected to the trans line. help???
Gator1980 is offline
post #2 of 11 (permalink) Old 11-13-2006, 09:58 PM
driller's Avatar
Here is mine...
It is a 1/4 inch brass tee with a compression fitting on the hard line and a hose barb to the cooler. The temp sensor is threaded into the branch of the tee with a 1/4 to 1/8 bushing so that the fluid flow is not impeded. You could just as easily have compression fittings on both ends.
driller is offline
post #3 of 11 (permalink) Old 11-13-2006, 10:32 PM Thread Starter
awesome!! thats how ill do it then. thanx jp!!
post #4 of 11 (permalink) Old 11-14-2006, 05:50 AM
4.3Lcougar's Avatar
there is a easier way!!!!!!! there is actually a bung plug on the 4r70w, its on the driver side, you might have to look around for it, but my sensor i got with the trans guage threaded right in it, and then all i had to do was route a wire to it... ive had it like this for over 2 years now and had no problem... but this was on a 3.8L though!
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #5 of 11 (permalink) Old 11-14-2006, 08:44 AM
driller's Avatar
There's actually several 'bung plugs' on the 4R70W. Better know which one's what when doing that.
You can also have a bung welded in the tranny pan, some peeps like to read the temps there. When installing the temp sensor in-line, then there's the argument of where to put the sensor, before or after the cooler.
If you're real adventurous, you could use a flaring tool and appropriate fittings.
driller is offline
post #6 of 11 (permalink) Old 11-14-2006, 06:35 PM Thread Starter
which trans line did you install your "T" fitting in? top or bottom line?? im gonna install mine before the cooler because i think thats the most accurate, being straight out of the tranny. so which one is the line pumping to the cooler???
post #7 of 11 (permalink) Old 11-14-2006, 08:54 PM
driller's Avatar
I didn't trace mine to the tranny. I ran the car and determined the 'hot' line from the cold line. I then put a red nylon tie on the hot line and a blue nylon tie on the cold line.
FWIW I put the gauge in after the cooler. Different stroke for different folks.
driller is offline
post #8 of 11 (permalink) Old 11-14-2006, 10:34 PM Thread Starter
thanx JP
post #9 of 11 (permalink) Old 11-15-2006, 08:10 AM
wether's Avatar
On a 4R70W the coolant return line is the top line going into the transmission and the bottom line is the output line.
wether is offline
post #10 of 11 (permalink) Old 11-15-2006, 08:48 AM
coggonobrien's Avatar
when installing a trans cooler does it matter which end of the cooler itself is the input and which is the output? i see nothing that species it on the cooler and I would assume that it doesn't matter sense it is just a receptacle for fluid to flow through. also does orientation matter? by that i mean do i specifically have to have the fluid come in through the top or bottom? again I don't see why that would matter. thanks, Dave
coggonobrien is offline
post #11 of 11 (permalink) Old 11-15-2006, 10:37 AM
wether's Avatar
On the cooler itself, no
wether is offline
