7.5 posi - TCCoA Forums
post #1 of 20 (permalink) Old 11-18-2006, 09:17 PM Thread Starter
Question 7.5 posi
Hey im kinda new but i got a question. I want to put a posi in my stock 3.8 96 thunderbird and it has a 7.5 rear. I just want to get a one that would be relatively easy to put in and replacing the least amount of the rearend. I need a little advice on what to get. Thanks
lxthunderman is offline
post #2 of 20 (permalink) Old 11-18-2006, 09:21 PM
Nativedetroiter's Avatar
Get an 8.8 rear end from any V8 MN12/FN10 and then get a trac-lok unit and put it all together.
That is what I did.
Nativedetroiter is offline
post #3 of 20 (permalink) Old 11-19-2006, 12:13 AM
4.3Lcougar's Avatar
Thumbs down
That is what I did.
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #4 of 20 (permalink) Old 11-19-2006, 07:36 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
I agree. Even if you just upgrade the 7.5 you still have to pull the whole pumpkin. You might as well upgrade to 8.8 for a few more $$$ and the same amount of work... it is a direct swap.
tinman_72 is offline
post #5 of 20 (permalink) Old 11-19-2006, 05:38 PM
The Turbo coupes before 1987 has trac lok 7.5's
PearlBirdSC is offline
post #6 of 20 (permalink) Old 11-19-2006, 07:31 PM Thread Starter
if i swap a 8.8 pumpkin for the 7.5 can i reuse my axles?
post #7 of 20 (permalink) Old 11-19-2006, 07:37 PM
Traveler's Avatar
You could always find an 8.8 that is already a trac-loc. Then its a direct swap (provided its the same ratio) Its still a direct swap even if you change ratios, you just have to change the speedo gear to. And as yours is a 96 I'd bet that you have a 3.27.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #8 of 20 (permalink) Old 11-19-2006, 09:45 PM
jk69cat's Avatar
yes they will work, but why not ugrade to at least v8 axles while you have it apart , you have to pull them from the knuckle anyhow
mn12 less!
jk69cat is offline
post #9 of 20 (permalink) Old 11-20-2006, 09:46 AM
tbirdtess's Avatar
Daily driver?
~~Hello
If this is your daily driver than a 7.5 will hold up. Find a super coupe in the parts yards. The super coupe should have a traction lok. Either axle's will work. The smart way is to purchase the whole rear K. Generally is would be cheaper because they have less work & you get all parts together. look for the L in the gear ratio tag.(like 3L55 8.8)
I run a 7.5 in my oval track car with 4.10 open(rule) gears. I have used both V6 & V8 axles. Remember I race from a rolling start. If you will be drag racing Even a little go with the 8.8 & V8 axles for sure. If you will be drag racing hard go with aftermarket axles.
PAUL
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #10 of 20 (permalink) Old 11-20-2006, 06:01 PM Thread Starter
yea this is just my daily driver with the v6 in it so which cars have the 7.5 posi in it with the gear ratio of 3.27 in it also the 8.8 posi. Thanks for the relies.
post #11 of 20 (permalink) Old 11-20-2006, 07:13 PM
jk69cat's Avatar
lets face facts s well, the chances of findign a used 7.5 trac lock is rare , i can count on one hand how many i have seen, 2 ! the 8.8 has much more availablity, ie cheaper !
mn12 less!
jk69cat is offline
post #12 of 20 (permalink) Old 11-20-2006, 10:51 PM
when you get one out of a Mark, its even aluminum, so its a little lighter. Then you can get the half-shafts at the same time!
post #13 of 20 (permalink) Old 11-27-2006, 03:39 PM Thread Starter
what are half-shafts? Will any 8.8 work even if its off a car that doesnt have independent suspension.
post #14 of 20 (permalink) Old 11-27-2006, 04:35 PM
wether's Avatar
Half-shafts are our "axles" coming out of the differential.
You can use the 8.8 pumpkin out of a non independent suspension (IRS) car but the rear end's side gears will have to be machined. There is an article about the machining instructions somewhere. . . . .I can't find it right this instant. . .sorry.
wether is offline
post #15 of 20 (permalink) Old 11-27-2006, 05:46 PM
jk69cat's Avatar
you need to be clearer on this! hes not talking the whole axle assembly just the actual differential inside ie the carrier,
mn12 less!
jk69cat is offline
post #16 of 20 (permalink) Old 11-27-2006, 06:05 PM
13's or Mildly Broken
I'd just go for the 8.8 over the 7.5 - have a better rear end for down the road - maybe you'll need it
Just for the record, my 91 used to have a 7.5 rear end and fairly sure it had TL. I'm looking for the pic of the rear end tag.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #17 of 20 (permalink) Old 11-28-2006, 03:52 PM Thread Starter
isnt the 8.8 rear a widder punkin so i would need shorter axles? also would the mark rear work in the rear without the half shafts without any machinging required?
post #18 of 20 (permalink) Old 11-28-2006, 05:15 PM
Ahh, nope. Same set-up, same lengths. Ford kept it simple for budget reasons, the car fits around all of it.
As for the Halfshafts, I wouldn't cut corners, even thought the V6 halfs can fit, once you see the difference between the two, you will want to go with the V8 ones.
Just don't cut corners. If you are upgrading your rear end, do it all the way.
post #19 of 20 (permalink) Old 11-28-2006, 06:47 PM
David_viny's Avatar
But if u can’t upgrade to an 8.8, the 7.5 is plenty strong for a daily driven v-6 car. That’s why Ford put it there.
I know of a few people with v-8 ford rangers with the stock 7.5 rear end and they are still together. But they haven’t put drag slicks or huge off-road tires on them yet so the tires spinning is sort of a shock buffer. There not as weak as people make them out to be and are perfectly fine behind a v-6, but it shouldn’t be behind a V-8.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #20 of 20 (permalink) Old 11-30-2006, 08:02 PM
7.5 traction lok pumpkins are avilable, but 8.8 traction lok are a lot easier to find. I can go out to the local wrecking yards any day of the week and find about a dozen MN12s with 8.8 traction loks, but I only see the 7.5s about 2-3 times a year. Whichever you were to choose would cost about the same as the other to purchase or rebuild. The 8.8 would bolt right in to your car and is a stronger piece.
Decy is offline
