AX4N question for the tranny gods - TCCoA Forums
post #1 of 7 (permalink) Old 11-19-2006, 10:43 AM Thread Starter
Ok, I just changed the trans fluid and filter on my step-father's car. It's a 98 sable with the 24V motor and it has an AX4N trans. The old fluid was pretty dirty, but not horrible, so I didn't think it was a danger to change it. After doing the trans service, the car shifts really hard, like chirping the 1-2 shift at half throttle. I double checked the fluid level, and it is right at the top of the cross hatching. At first I thought that maybe the computer just needed to relearn the shift patterns or something, but I have driven the car about 50 miles, and there has been no improvement. Anyone know what happened?
Mike
post #2 of 7 (permalink) Old 11-19-2006, 11:55 AM
Any codes? The 1-2 hard shift on those transmissions can be a sign of several things. Valvebody problems and epc solenoid problems are the most common. It seems if anything goes wrong you get that problem. Are you sure you used the correct filter and the trans is properly filled?
post #3 of 7 (permalink) Old 11-19-2006, 03:49 PM Thread Starter
Well all the shifts are hard, not just the 1-2. It's just more pronounced on the 1-2, I think because you are going slower, but it upshifts hard into every gear (downshifts when slowing down are still perfectly smooth). Even if I lift the pedal to let it shift, it still jerks the car forward pretty hard. It is definitely the right filter, had them side by side to make sure, and the fluid level was right at the top of the cross hatched area. When I first drove it, I went about a mile and noticed the hard shifts, so I pulled it back in and checked the fluid level and it was fine. I haven't checked it since then though. Also I haven't had a chance to check for codes since doing the trans service. I'll do that monday. I know it does have a code for VSS intermittent because what he originally complained about was the speedo jumping around when he's on the highway. I ordered a VSS for it, and it will be here monday, but the car didn't have the hard shifts with that code before the trans service, so I don't think that's causing it.
post #4 of 7 (permalink) Old 11-20-2006, 05:12 PM Thread Starter
Ok, I just got back from the shop. I checked for codes, and the only code present is the VSS intermittent that the car had before I changed the fluid. I used the scanner to make a movie of accelerating and the car shifting through the gears, and I noticed something that didn't make sense to me. It seems like shift solenoid 2 is working backwards I think. Here is the data from the movie. It was a half throttle run up through all the gears.
Vehicle speed - 0mph
Gear - 1st
Shift solenoid 1 - off
Shift solenoid 2 - on
Shift solenoid 3 - off
Vehicle speed - 34mph
Gear - 2nd
Shift solenoid 2 - off
Vehicle speed - 45mph
Gear - 3rd
Shift solenoid 1 - on
Shift solenoid 3 - on
Vehicle speed - 52mph
Gear - 4th
Those last 2 really confuse me because the car definitely has all 4 gears, and the only problem noticed is when shifting, but it is showing all 3 shift solenoids on for 3rd and 4th. There is no drag or anything, and the car still has plenty of power. First off, wouldn't having all the solenoids on lock the trans? And even if it didn't, you couldn't have the same solenoids on for both 3rd and 4th gears right? I only know the basics about how the trans works, so let me know if I am missing something here, but this data is really confusing me.
Mike
post #5 of 7 (permalink) Old 11-21-2006, 02:28 PM
check out www.tcca.com
I just took my 02 taurus in for tranny trouble.
I've read that when the VSS acts up in the AX0D, AX4N, etc. trannies, it makes them run a little rough.
My problem was a broken clip on the servo.
post #6 of 7 (permalink) Old 11-21-2006, 06:13 PM Thread Starter
That link brings up some kind of search engine
As for the VSS, I got the new one and will replace it tomorrow, but the car had the VSS code before I did the trans service, and it shifted absolutely perfect, so I'm not sure that's the problem. It might be a contributing factor, but I think something else is wrong here, otherwise it's just a big coincidence that it happened as soon as I did the trans service. Also those shift solenoid on/off patterns don't seem right to me, but I don't know for sure. Hopefully I can figure this out soon.
Mike
post #7 of 7 (permalink) Old 11-21-2006, 09:15 PM
Mike
sorry about the link.....try this one, http://www.realtcca.com/forum/index.php?act=portal
