leaking fluid :'( - TCCoA Forums
post #1 of 11 (permalink) Old 11-21-2006, 12:26 AM Thread Starter
leaking fluid :'(
recently i had my tranny pan gasket changed because i was leaking fluid. i started parking in the driveway again (had to stop because it was eating the paving) and i noticed i was still leaking stuff. seems that im still leaking tranny fluid because it has slipped 2 or 3 times since the replacement. now even with the heat on i can smell tranny fluid. what could this be? im at just about 97k miles, how much longer will it be before everything decides to go at once.
(cant remember if i filled out the profile info, i have a 1995 cougar 4.6l, no mods)
HystericPoison is offline
post #2 of 11 (permalink) Old 11-21-2006, 08:40 AM
driller's Avatar
What gasket did you use?
Are you absolutely sure it wasn't the dipstick o-ring?
driller is offline
post #3 of 11 (permalink) Old 11-21-2006, 09:15 AM
wether's Avatar
If you are smelling tranny fluid and you still have the stock exhaust, then I am betting that the extension housing has vibrated loose with mileage. It is easy to check. . . . .see if the tranny fluid is hitting the "y-pipe" where the exhaust comes together at the transmission k-member. If so, get under there and see if you can turn the extension housing bolts by hand. . ..I'll bet you can. It is a fairly simple fix, but quite involved to fix. I have put the instructions on this thread:
http://forums.tccoa.com/showthread.php?t=92313
Hope this helps. . . .
wether is offline
post #4 of 11 (permalink) Old 12-11-2006, 07:36 PM
frankjc's Avatar
Send a message via Yahoo to frankjc
Does yours leak out the little access cover in the bellhousing? Mine is doing that.
Drive it like you stole it!
frankjc is offline
post #5 of 11 (permalink) Old 12-12-2006, 12:49 AM
Sounds like the front pump seal at the transmission could be gone for you. If you plan on stopping that leak, better make time to remove the trans.
post #6 of 11 (permalink) Old 12-12-2006, 07:39 AM
frankjc's Avatar
That was my initial though. I talked to a transmission guy about it and he asked me a bunch of questions, one of which was if the fluid was dripping on the converter, which it wasn't when I looked. He said based on that, it probably wasn't the front pump seal. He mentioned some assembly that wears out and causes fluid to leak down the front of the transmission. I can't remember what he called it.
frankjc is offline
post #7 of 11 (permalink) Old 12-15-2006, 10:40 AM
SVT BIRD's Avatar
Thumbs up Check your Dipstick tube !!!!
I have a 97 Bird and I had a leak coming from the transmission, so I decided to replace the gasket and while I was doing that it made a good excuse to replace the original trans pan with a deep aluminimum pan. After the new pan was installed I still had the leak, It was hard to tell where the leak was comming from with the fluid all over the trans and the exhaust. After a good clean up I raised the car on jacks, my driveway has a downward slope, and found the fluid was comming from the front passengers side of the trans. I pulled the dipstick tube replaced the oring and sealed the outside of the tube with silicone sealer. No more leak. I hope this helps.
SVT BIRD is offline
post #8 of 11 (permalink) Old 12-15-2006, 02:54 PM
frankjc's Avatar
The dipstick tube o ring wouldn't make it leak through that access hole in the bellhousing, would it?
That would be great if that was it.
frankjc is offline
post #9 of 11 (permalink) Old 12-15-2006, 03:54 PM
Not a chance.
post #10 of 11 (permalink) Old 12-15-2006, 06:32 PM
frankjc's Avatar
Here is a picture from the Ford manual.
Look at the drip running down the bellhousing. That seems like what mine is doing.
I am not sure if i should:
A) Replace the seal, and gasket between the pump and transmission.
B) Buy a front pump off EBay.
C) Replace the whole transmission.
The transmission does have a couple other problems. The valve body buzzes, although it may have stopped since I changed the fluid.
It shudders occasionally, even with new fluid. I did NOT use MerconV.
It seems to slip when it's cold.
Funny thing, right after I change the oil filter adapter gasket and stopped that leak is when this one started to get bad.
frankjc is offline
post #11 of 11 (permalink) Old 12-20-2006, 09:39 AM
frankjc's Avatar
This seems like what I have going on.
http://forums.tccoa.com/showthread.php?t=54773
frankjc is offline
