just want to make sure.... - TCCoA Forums
post #1 of 4 (permalink) Old 11-25-2006, 09:51 AM Thread Starter
ThunderBeast86's Avatar
Send a message via AIM to ThunderBeast86
I've priced it out a couple different ways, and this appears to be the cheapeast....
If I buy an old 3.08 aluminum open carrier from a MarkViii, swap into it a rebuilt 28 spline 8.8 track-lok from a mustang, and install the gears and everything, it should all work?
Is it the Pumpkin or the track-lok that needs to be shaved on a solid 8.8?
I believe it's the pumpkin, so if the pumpkin is alum. from a markviii, and the track-lok from a solid 8.8, it should still work perfectly, correct?
Anything else I should be aware of?
I plan on purchasing:
3.08 open alum. pumpkin
4.30 motive Gears
Track-lok w/ rebuild kit
Install kit
anything else?
(besides the obvious 1 piece alum driveshaft)
Btw, where is everyone getting their driveshafts from nowadays? I know the group purchase got some decent ones, but someone else posted up a place that was like $250....but it was arguable whether it could handle 4.30 gears or much RPM....so where are most people going?
2.25" True Dual Catless DI/DO Magnaflow Exhaust, Eibach Springs, Addco 1 3/8", J-mod, Viper 791 Alarm, Clarion 855 full color touch-screen, Directed 2400 amp , 2 12" CV Strokers with a custom ported box, K&N air filter, 180* T-Stat, Xcal2 SCT TUNED BY LONNIE 17 x 7.5 (245/45/17) Chrome Cobra R's, 17x9 in back(275/40/17)
DOHC sitting in the garage
Teksid 2v plans?!?!
Tranny Cooler, Dual Remote Oil Filter waiting for install
ThunderBeast86 is offline
post #2 of 4 (permalink) Old 11-25-2006, 10:08 AM
The side gears need to be the IRS ones or they need machined. The gears are with the trac-loc, not the pumpkin or the carrier on an open rear. I don't remeber is a groove for a retainer is what it needs, or a bevel, there is a picture posted here recently that shows the difference.
That should be all that you didn't list above.
Bangster is offline
post #3 of 4 (permalink) Old 11-25-2006, 10:34 AM Thread Starter
so if I buy the track-lok separate....and ship it to Dirty, to have him machine it.... I can take the machined Track_lok (originally from a solid rear), throw it into an alum. open carrier (won't be open diff. anymore), with the rebuild kit, and install kit? This will be easier...I'll just have it shipped directly to Dirty, instead of having to ship the whole carrier, I'll only need to ship the track-lok to be machined- is what you're saying, right?
Teksid 2v plans?!?!
post #4 of 4 (permalink) Old 11-26-2006, 01:30 AM
I understood it as if you reuse the side gears from the traction loc pumpkin, they need machined. If you use the side gears from the IRS unit, they do not. Actually will be doing this to my Mark VIII in the future and thought the rears were the same as far as the gears go, just different pumpkins for traction loc.
Brian
bdubyah is offline
