Abs car - non abs axles ? - TCCoA Forums
post #1 of 9 (permalink) Old 12-04-2006, 07:24 PM Thread Starter
tbird462002's Avatar
Wondering if i can use non abs axles in my car which has abs. And if so will the rear abs just not work or what will happen.
2.25 Mid-mount true dual exhaust,
K&N cone , 22c plugs , Magnecor 8.5 wires, Addco 1 3/8 swaybar, XCal 2 , 02 Gt maf,Vogtland Springs, Sport Fronts-Cobra Rears,RSTB, Auburn Pro w/3.73s, Steeda IRS Brace
tbird462002 is offline
post #2 of 9 (permalink) Old 12-04-2006, 08:30 PM
If the non ABS axles do not have the sensor rings, you will not have ABS brakes.
birds4us is offline
post #3 of 9 (permalink) Old 12-04-2006, 08:53 PM
Yes, you can use them and drive the car. No, you cannot use them and everything be correct. Halfshafts for ABS cars have a sensor ring and without it, you'll set off your ABS light and won't have ABS. You'll also lose traction control if you have it.
post #4 of 9 (permalink) Old 12-04-2006, 08:57 PM
95xbird's Avatar
Hmmm....Wont the non ABS shaft clash with the Hub.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #5 of 9 (permalink) Old 12-05-2006, 06:36 AM
nickleman60's Avatar
the abs rings (sensors) are on the side of the axle closest to the rearend, it has nothing to do with the hub end of the axle, they're the same.
94 SC AUTO - $$$$ Pit
nickleman60 is offline
post #6 of 9 (permalink) Old 12-05-2006, 01:59 PM Thread Starter
so they will fit then but will my car be messed up or the abs light will just be on
post #7 of 9 (permalink) Old 12-05-2006, 02:15 PM
I think everything has been said in this thread. The abs and/or traction control will not work if you do not have the toner rings for them. They will fit, they just won't work completely correct.
post #8 of 9 (permalink) Old 12-05-2006, 02:25 PM
twin turbo 281's Avatar
if you want to feel what your car would be like without abs pull the high current fuse and turn off the traction control. Thats what its going to be like without the rings..except the front might still work? Idunno?
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #9 of 9 (permalink) Old 12-05-2006, 04:52 PM
No, the front won't even work. It's not a split system. If one sensor fails, the whole system is shut off.
