94 LX Trans observations - TCCoA Forums
post #1 of 1 (permalink) Old 12-21-2006, 05:28 AM Thread Starter
OK My project Bird is on the road. My primary trans complaint was a large flare on the 3-4 shift. That is definately there. I primarily manage that by keeping the O/D Off switch on disabling Overdrive for now.
If not the RPM flares up by about 1000-1500 RPM and the delay to shift (3-4) is about 1-2 seconds.
Also I can be cruising and turn the O/D Off switch off and the 3-4 shift (with accompanying flare) will happen within a few second.
Other things I have noticed that seem a tad odd.
Manually down shifting from D-2 (at say 30 MPH) with NO THROTTLE applied the tach will drop to 1000 for about a second and then the 2nd gear will engage and the tach will rise accordingly. The same exact scenario happens if I manually downshift from 2-1.
Also with selector in D and O/D turned on or off the car will downshift during coast a tad early to my way of thinking. I can actually feel some slight decel and engine braking during coast from say 25-10 MPH. Tach jumps (500 RPM?) on both downshifts (3-2 and 2-1)
Plan to change fluid and filter soon including converter drain.
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
