? About rear end - TCCoA Forums
post #1 of 6 (permalink) Old 12-26-2006, 03:25 PM Thread Starter
soundman502's Avatar
? About rear end
I've looked up the VIN number, and I've gone throught the identifiers, and my car is supposed to have an open 3.08, and though I could be mistaken, I have always thought that it would be a one wheel wonder with that gear set. But I was pulling a old 60's Chevelle through the mud the other night, and my right wheel spun for a second or so, and then the left side kicked in. I've always thought of that as a limited slip type of function. Do I have my definitions wrong, or should I look more closely at the pumpkin itself and see if it's been changed out? Thanks!
1996 Thunderbird LX 4.6L 147,000 mi.
Mods: Stock
1979 Ford Bronco Custom 5.8L Modified 188,000 mi.
http://www.cardomain.com/ride/2547728
soundman502 is offline
post #2 of 6 (permalink) Old 12-26-2006, 04:04 PM
if both wheels spin at the same time it's not open.
sleepinggt is offline
post #3 of 6 (permalink) Old 12-26-2006, 04:06 PM Thread Starter
From what I can tell, they weren't spinning at the same time, more like alternating. But I can't tell yet, I'm going to try to force it again and see what I can find out. It didn't spin a wheel after the left side took over, just pulled till I stopped. Is there a number on the pumpkin itself that may give me clues?
Mods: Stock
post #4 of 6 (permalink) Old 12-26-2006, 04:51 PM
Sounds like an open rear to me.
Jack up the rear. Both wheels off the ground. Leave it in park. Try to rotate one wheel.
If it rotates and the other one rotates the other way, it is open.
If it resists rotating put it in neutral, rotate the wheel. If they rotate together after resisting rotation in the first test it would seem to be LS.
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
post #5 of 6 (permalink) Old 12-26-2006, 04:53 PM Thread Starter
Alright, thanks, I'll check into that. I wouldn't care, except for the fact that I live in Indiana, which so far has had a mild winter, but they can get fun, and I've been looking into throwing a set of 3.73's in at some point, when I'm not broke! Thanks for the info, much appreciated!
Mods: Stock
post #6 of 6 (permalink) Old 12-26-2006, 09:07 PM
Take the cover off and see if you see the s spring.
sc0tty8 is offline
