Fluid change - TCCoA Forums
post #1 of 1 (permalink) Old 12-30-2006, 10:45 AM Thread Starter
Fluid change
OK I went ahead and did it. I drained it all out (incl. converter) and replaced the filter. I added 12 quarts of Mercon V.
I also upgraded the MLPS while I was under there. I have some observations and some questions.
Observations.
1. The 1-2 shift is now MUCH softer.
2. Reverse engagement is more delayed than before.
3. 3-4 shudder seems to be gone.
4. 3-4 flare has not happened again but that was intermittent to begin with.
Questions
1. The MLPS came with instructions that implied I had to do some rewiring. I seemed to have the correct plug already. I believe the rewiring might have only been for earlier years. (I have 1994 LX 4R70W)
2. The MLPS instructions said to choose the "appropriate spacers" It came with 4mm and 8 mm spacers. My old unit had no spacers and the new "seemed" to not need spacers. I did not use either. Have I created a problem?
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
