Transmission Q? - TCCoA Forums
post #1 of 2 (permalink) Old 01-04-2007, 02:46 AM Thread Starter
Arrow Transmission Q?
wat other vehicles have the same tranny as a 95 Cougar XR7 4.6
95CougarXR7 4.6OHC is offline
post #2 of 2 (permalink) Old 01-04-2007, 09:29 AM
Every T-bird and Cougar from 94 to 97. Crown Vics (not the police version) and Grand Marquis, Mustangs... Keep in mind that the newer transmissions will need the harness re-pinned to work correctly, and there is a write-up here on how to do it. It's not too hard.
If you are in need of a new trans and want to keep it stock, then I would go with at least a 99 or newer trans as there have been many updates to the strength of the trans. The 95 was not known to be a strong transmission.
If you plan on adding some performance to it, then talk to Darrin about having one built and grab a converter from Alan.
Jay
FordMan77 is offline
