tranny cooler hard line hookup - TCCoA Forums
post #1 of 12 (permalink) Old 01-12-2007, 10:31 PM Thread Starter
ZackG's Avatar
I know I know this has been talked about forever and forever many and many of times, but im braindead from my monitor glow. My tranny cooler has 1/2" NPT female threads on it. And of course the hardlines are 3/8" (correct me if im wrong). can someone posts linkes on jegs or summit for what I need to hook up the hard line to it? I dont want any AN steel braided lines, only the stock hardline. Thanks much for the info.
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #2 of 12 (permalink) Old 01-13-2007, 12:33 AM
http://forums.tccoa.com/showthread.php?t=46351
The fittings on your cooler you can buy brass fittings that go right in there. Double check they aren't flared inside, many of the aftermarket coolers will accept steel 3/8 tube directly and they usually supply a fitting to switch to a barb. I prefer direct 3/8 however on most vehicles I like a flex point of abut 6-8 inches where the lines connect to a short piece of rubber. A nice place to put a filter after a transmission overhaul to catch any remaining pollutants. Don't forget to flare the lines I keep hearing I didn't and it's working fine. Thats illogical thinking to me. It only takes a few seconds of starving your transmission of fluid to do permanent damage. Also consider all the normal debris on first change after a rebuild. Generally that is friction material and leftover from the old radiator. There are machines out there to shear the frictions and reduce that, but I don't know of anyone using them.
post #3 of 12 (permalink) Old 01-13-2007, 06:29 AM Thread Starter
ZackG's Avatar
alan, i know that much info. I already have one in there and planned on putting another next to it. I didnt plumb the first one, i let a mechanic do it. He has hard line all the way through it except for about 2 inches of rubber hose just before and after the cooler. The model i have doesnt have any hardware
http://store.summitracing.com/partde...5&autoview=sku
You say most will accept the hard line directly, I believe this, but what fastener do i need? Thanks much for the link though
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #4 of 12 (permalink) Old 01-13-2007, 10:55 AM
Well you need a fitting that is 1/2 npt to 3/8 inverted flare. I'd have to double check it but that sounds like a 4r100 case fitting.
post #5 of 12 (permalink) Old 01-13-2007, 04:25 PM Thread Starter
ZackG's Avatar
oh you mean the GM trannies have a 1/2" NPT threading?
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #6 of 12 (permalink) Old 01-13-2007, 04:36 PM
4r100 is ford truck, large transmission.
post #7 of 12 (permalink) Old 01-13-2007, 05:00 PM
coggonobrien's Avatar
correct me if i'm wrong but did they switch to 3/8 at some point? i'm pretty sure my 94 has 5/16
coggonobrien is offline
post #8 of 12 (permalink) Old 01-13-2007, 05:04 PM
oh hey, just read ur other post about switching over, do you now the part number for the explore trannie connectors? i scouted the local junkyards and no dice on explorers
post #9 of 12 (permalink) Old 01-13-2007, 07:44 PM
Brass ones are easy to get at any parts store, I prefer the OEM steel ones, but I have used the brass many times as well. I do not have the part number ask Jason maybe.
post #10 of 12 (permalink) Old 01-13-2007, 08:07 PM Thread Starter
ZackG's Avatar
my bad, i meant to type ford. but they do? ill have to inquire about this.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #11 of 12 (permalink) Old 01-14-2007, 07:47 PM Thread Starter
ZackG's Avatar
ok i think im wrong. stock tranny lines are 5/16ths, not 3/8ths?
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #12 of 12 (permalink) Old 01-14-2007, 08:24 PM
Yep.
