Adjusting clutch. - TCCoA Forums
post #1 of 2 (permalink) Old 01-28-2007, 10:16 AM Thread Starter
Adjusting clutch.
93 Mustang LX with a T5.
Just had the used and abused transmission rebuilt. Has an aluminum quadrant. Resurfaced the flywheel, new pressure plate 2300lbs, new disc, new roller pilot bearing and throwout bearing.
I tightened the cable end onto the fork until the cable was not slack then tightened about 3 turns more. I'm confident the throwout bearing is constantly touching the fingers, even with the pedal released.
Car shifts fine, no problems engaging gears including reverse.
Why I'm concerned. Releasing the pedal from the carpet it will engage about 1/3 the way up.
I tried tightening the cable another turn but it still engages about 1/3 the way up.
I don't want to tighten it too much but before I was engaging about 2/3's the way up.
95 Thunderbird LX 4.6L 15.5 @ 88
94 LHS 3.5L 15.8 @ 88, wife's car
87 Ram 5.9L 15.0 @ 87
69 Super Bee, under construction
65 Plymouth Belvedere 225cid, wife's toy
http://www.cardomain.com/ride/755303
jfsram is offline
post #2 of 2 (permalink) Old 02-04-2007, 07:42 PM Thread Starter
Bump'
jfsram is offline
