7 or 8 tooth speedo gear? - TCCoA Forums
post #1 of 11 (permalink) Old 01-30-2007, 11:53 AM Thread Starter
i got a 91 xr7 with a 5.0 and there are 2 different part numbers for this model. one is for a trans with a 7 tooth gear and the other is for a 8 tooth. how could i find out? thanks
also the 8tooth is 100$ more.
5.0_Mo is offline
post #2 of 11 (permalink) Old 01-30-2007, 01:38 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
do you need a replacement gear? crawl under the car and unbolt the one bolt holding the vss to the tailshaft of the tranny on the driver side. the gear is inside the vss. count the number of teeth.
and how can a little plastic gear even cost $100? hope thats a typo...
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 11 (permalink) Old 01-30-2007, 03:11 PM Thread Starter
i just realized i forgot to mention the part numbers were for the transmissions then selves but the description said one trans was an 8 tooth and the other a 7 tooth. the 8 tooth trans was 8xx and the 7 tooth was 720
5.0_Mo is offline
post #4 of 11 (permalink) Old 01-30-2007, 03:50 PM
He's referring to the drive gear inside the transmission.
It's only funny until someone gets hurt.
Then it's freaking hilarious.
Adventures in ChumpCar Racing
Tobey is offline
post #5 of 11 (permalink) Old 01-30-2007, 03:57 PM
I don't remember which one my 89 3.8 Cougar had, but the replacement AOD from a V8 mustang was the other one. The tranny shop tried to get it right (pacing the car with a truck with 4 different sized tires, rags stuffed into the fuel fillers, among other rednecky stuff) but I eventually took it to a speedometer shop with a syno to get it right.
Obviously there is another difference that names it 100 dollars difference for the tranny. It would be best to get the one with the same number of teeth on the output shaft if all else is equal. The gear to get the speedometer right is 10-20 bucks.
Bangster is offline
post #6 of 11 (permalink) Old 01-30-2007, 04:09 PM
The driven gear is machined into the output shaft of the transmission. Buy the cheaper one. If it's the wrong one, a new driven gear is $20, so you still come out $80 ahead. Go to www.fordracingparts.com and download a catalog. Page 139 has all the speedo gear info you'll need. If you have 3.08 gears and the 7-tooth drive gear, you'll need the 18-tooth driven gear (Gray). For 3.27 gears, you'll need the 19-tooth gear (tan).
Come to think of it, what color is your driven gear, the one on the VSS?
Tobey is offline
post #7 of 11 (permalink) Old 01-30-2007, 04:19 PM
Motorboatin' SOB
big mike's Avatar
that aint what the title says
2014 GT
1990 300ZX TT
big mike is offline
post #8 of 11 (permalink) Old 01-30-2007, 04:55 PM
fast Ed's Avatar
If you're talking about an AOD, the speedo drive gear is machined in the output shaft of the trans ... it's not a separate plastic gear like some other transmissions.
Ford parts catalogue shows an output shaft with a 7-tooth gear for 91 Cougar.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #9 of 11 (permalink) Old 01-30-2007, 05:48 PM
91 is a questionable year. The SC's were 8 tooth, what gears does your car have stock? That should be a good clue. It really doesn't make a difference you can change the plastic gear to match. You can use the 8 tooth shaft with up to 3.27:1 gears. The 7 tooth shaft can be used with up to 3.73:1 gears.
post #10 of 11 (permalink) Old 01-30-2007, 07:38 PM
Yes it does. The drive gear inside the transmission IS one of the two speedo gears.
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
post #11 of 11 (permalink) Old 01-31-2007, 07:33 AM
Motorboatin' SOB
big mike's Avatar
when he says speedo gear, im thinking the one located on the tailshaft.
carry on...
2014 GT
1990 300ZX TT
big mike is offline
