turbo coupe 3 speed???? - TCCoA Forums
post #1 of 3 (permalink) Old 01-30-2007, 11:08 PM Thread Starter
rednsilver94sc's Avatar
Send a message via AIM to rednsilver94sc
i was out in the junkyard the other day and i found a turbo coupe that had a shift knob in it the knob appears to be old but in good shape its got a a different shift pattern
R 2
1 3
rednsilver94sc is offline
post #2 of 3 (permalink) Old 01-31-2007, 08:21 AM
Traveler's Avatar
I'd bet that someone just put a different shift knob on a 5-speed turbo coupe.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 3 (permalink) Old 01-31-2007, 04:19 PM
Turbo Coupes had T5 transmissions, with no exceptions that I'm aware of (except for the automatic models, of course). The T5 is a 5-speed transmission. Traveler is most likely right. Try shifting the transmission if you can and see how many gears there are to be sure.
SloMo228 is offline
