speedometer gear? - TCCoA Forums
post #1 of 7 (permalink) Old 02-06-2007, 06:52 PM Thread Starter
speedometer gear?
trying to get my speedo closer to the right speed.swapped a motor and transmission from a 97CV to my 96 bird.at seventy,speedometer says 80...put in a 20 tooth gear and it seems closer(have to check later with gps)...the gear is black though. just found out that this was meant for a manual transmission.could this harm the transmission?
shelbyseven is offline
post #2 of 7 (permalink) Old 02-09-2007, 08:21 AM
88grandmarq's Avatar
Send a message via AIM to 88grandmarq Send a message via Yahoo to 88grandmarq
yeah, 20 T black gear is for the manual trans, 20T orange gear is for the automatic. the only difference is is the snout on the end of the gear is longer for automatic transmissions. you can use the manual gear, but it wont seat/mesh correctly and will evenually strip the plastic gear teeth off.
you may need to go to a 21 T purple gear.
88grandmarq is offline
post #3 of 7 (permalink) Old 02-09-2007, 05:08 PM Thread Starter
thanks for the information.going to check it again with a GPS sunday.
post #4 of 7 (permalink) Old 02-09-2007, 05:19 PM
conversion02's Avatar
check out
http://tccoa.com/articles/gears/index.html# and click on gears if you need any other clarification
conversion02 is offline
post #5 of 7 (permalink) Old 02-11-2007, 05:32 PM
svtbird88's Avatar
Steeda also has a 23t black gear for the automatics. I have yet to find anyone with a 22t gear for the automatics though.
svtbird88 is offline
post #6 of 7 (permalink) Old 02-11-2007, 07:26 PM Thread Starter
ordered a 21 tooth purple from mustangs unlimited...shipping was almost as much as the part...
svtbird88 they also had a 23 tooth gear,i believe it was 17.95...compared to 8.95 for the other gears...
post #7 of 7 (permalink) Old 02-13-2007, 07:07 PM
svtbird88's Avatar
The 23t one from steeda is what I have now.
